Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Maytag MFD2561HES I previously posted this problem, but had the wrong model number on the post, and the solution did not work because I messed up the model number. My problem is: Everything in the left crisper freezes, and the water dispenser (on left wall) is froze up and does not work..Any advice would be greatly appreciated! Thank-you!!
  • 958 Answers
Check your thermostat setting. you could have set it too low. if not , you can see and check if it uses a duct thermostat where in it supposed to close the duct if the temperature of the cabinet is already cold. it may be stuck open.
Posted on Feb 05, 2008
I just went through this problem after a major power outage from our December 2007 ice storm. I was able to reset the controller (computer?) to factory defaults and the water dispenser started working. I think it was just confused!
Posted on Feb 28, 2008
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
Older model dishwasher doesn't drain at the begin of cycle or turn on water.The timer seems to work all the way through turning off and on at each function and the fan seems to work alright.
Hello, welcome to FixYa. I understand you have a Maytag dishwasher based on your post, correct ? If so could you post a reply with the model number of this machine and I'll see what I can find for you. There were some recalls on Maytag units a while back, but I don't want to speculate...it's better to wait for the model number, in fact a serial number as well would be even more beneficial. I look forward to your reply and assisting you going forward. I hope you can appreciate there are many scenarios even within the "Maytag" brand. Thank you. Regards, Macmarkus :)
Sep 24, 2011 | Maytag Dishwashers
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
Jun 14, 2011 | Maytag Ovens
Have a MFD2561HES refrigerator and both the
i would call who ever replaced your compressor usually they warrant their work for maybe 3 months or so he might have had a bad weld he made when joining tubes,,, it is worth a shot
Jan 31, 2010 | Maytag Refrigerators
Maytag Ice20 refrigerator
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
Jul 09, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Sony?
i would have to know what the symptoms are and what the model number is. if you reply to this same post everytime we have a way of having all previous posted info available if you open a new post I have no way of determining what the problem is.
Jun 26, 2008 | Televison & Video
Maytag 2 speed replacement motor
you may have wrong part , post model serial , and part number that you have i will look them up
Nov 29, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
548 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
