No water in the drum
THere is no water what so ever visible in the drum when the washing is being washed, the washing looks wet, but it is not being dipped into anything. Is my brand new wahing machine broken or is this normal with these new types? Still the washing does not feel really clean when I get it out.
  • dandulka Feb 05, 2008
    Hmmm, it is a DAEWOO DWD FD 1411 B washing machine. I was watching the whole programme (as desperate as it sounds) and there is no other water coming in except for the water coming in through the upper part where you load washing powder. I found out also that this machine works with air bubbles and some silver nano particles, but I still believe that for bubbles to work there should be water in the drum.
    It is a brand new machine, but they delivered it already broken - the water pump did not work and had to be replaced. Plus I had terrible trouble with the service - took them ages to come by. Therefore, I am trying to find out whether the machine is behaving normally before I have to go through the whole pain of fighting with mechanics to come and fix it. And indeed, the machine is still under warranty, but the service sucks. Thank you for your reply. Daniela
    Problem Solver:
  • 10 Answers
You have to know if the water pressure is good,
Are you sure the hose is not kinked, you should be able to hear a steady hissing sound when the machine is filling with water, is the drain pipe above the level of the machine, it must be for the water not to just drain away.
many modern machines do not take much water but if the washing is not clean then I suggest you get a mechanic to look as they may be able to increase the dip level a bit, if the machine is fairly new, it should be still under warranty??
Posted on Feb 04, 2008
Wash Capacity WF810W
wash capacity?? what is the dry weight?? you meen
did you look at the manual ???
i see its a 7KG machine so 7KG DRY weight
wet weight LOL
what type of water and what did you put in the drum
so its a 7KG machine
so you can put in 7KG of matter to then get wet and get washed
Mar 05, 2015 | Whirlpool Washing Machines
Hoover washer dryer - not sure it is filling with enough water
How old is the machine and which wash cycle are you selecting? Newer machines use very little water; it is not needed.
Mar 08, 2014 | Dryers
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Whirlpool Duet 9150.. should I be able to see water in the tub when it is washing? There is no visible water level. The clothes are wet but how do they get clean?
water is drawn THROUGH the clothes. There is a BIT of water in the drum - however the water sprays on the clothes during the wash cycle and draws the dirt/water/detergent THROUGH the clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough Water in Washing machine
i think the problem came from a rins water is little
1- you will check the pressur of water inlet it is easy throuw the soap drawer
2-try to clean the inlet water filter by teeth brush
good work thanks
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water still leaking
Look at and examine the door seal closely for any sign of a hole or tear in it.
If none is visible then it could be the clamp or spring that holds the seal to the drum front that is causing the prob..
Other than that , there could be a crack or hole in the container front.
Jan 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
