Cars & Trucks Logo
Posted on Jan 06, 2010
Wanna change the engine in my ae92 corolla.
At present i have a 5a engine,that;s giving trouble.i would like to know between the 5a and 4a which is better/
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Feb 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
9446
Points
30
There are many different types of 4a engines including 4a 4af 4age 4agze but the 5a is a 1.5 8v engine the 4a is a 1.6 usually a 16v. a 4age is a 1.6 16v gti engine that produces 129bhp depending on year later models had a little more. both engines are fuel injected and were produced for roughly the same period of time. from my experience a 4age goes on for ever. hope this helps
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
1helpful
Cant find the firing order from my 1983 Toyota Corolla 4A 1.8
Corollas made from 1993 to 1997 had two engine choices, the 1.6 liter 4A-FE and the 1.8 liter 7A-FE (click here for many details, comparisons, and diagrams).
Fig. 2: Firing order- 4A-C engine (other A-series similar)
1helpful
Ae92 automatic transmission is driving with one gear wont change
You have a failed component in the transmisssion, have it tested for a potential fault code.
What is the tappet settings for suzuki f5 engine
ae92 engine intake 0.15-0.25mm ex 0.20-0.30mm
2answers
'95 Corolla Engine Question
An engine from another Corolla up to 1997 will fit. There are 2 engines though. 4A-fe (1.6L) or a 7A-fe (1.8L) They look similar but run different Engine managment computers. The 4A-fe uses a 3spd auto trans and the 7A-fe uses a 4spd auto trans. Also some of the wiring may be different.
Hope this helps.
4helpful
Need torque settings for 1985 4A corolla cylinder head
hey, torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
WIRING DIAGRAM TO FIT FACTORY ELECTRIC WINDOWS TO AE92 COROLLA
Well black wire should be your earth wire. But are you going from window motor to car or from car to window motor?
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
