Question about GE GDS18LBR Bottom Freezer Refrigerator
Fridge stopped working
My freezer is still working, but the fridge just died. I pulled the unit out and vacummed the return (which was filthy). Do you have any thoughts on what the problem might be, and how serious it will be?
  • Anonymous Jun 05, 2008
    frig not cooling///freezer ok
    pds18sb
  • montecristy0 Aug 07, 2008
    the bottom freezer work but top refrigerator dont what can i do?
  • 109 Answers
If freezer section is still cold yuo have either abad evaporator fan or a defrost issue, is the back of the freezer compartment frosty? if so look for defrost problem, (open defrost thermostat, open heater, or bad defrost timer.
Posted on Mar 30, 2008
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Have an upright Brandt fridge/freezer A-Class. The freezer is on the bottom with the fridge above. At the top of the fridge there is a AMS (air moving system). The freezer works fine but the fridge is not...
the freezer has ice build up which is blocking cold air from being blown into the fridge,defrost entire unit overnight and retry if good but fault returns then you have a defrost problem
Jan 31, 2018 | Refrigerators
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Our fridge is not keeping cool. both the fridge and freezer stopped working yesterday, then we vacummed it out- the freezer works but the fridge is only at 39 degrees. Help?!!!
If your freezer is working properly.(that is it freezes ice)and frig is at 39 dg then you most likely have a problem with air flow . set thermostat and air control at middle setting and leave there for a few hrs. You should see temps stabilize with some time.
Dec 31, 2010 | Kenmore Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Maytag side by side fridge.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
214 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
