Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer will copy - will not print
I have a MFC 240C for a Mac that has stopped printing. I can still make copies but it will not print any documents. I replaced the USB cord with one that I know works. The cartridges are not empty (as it still copies). Please give me some ideas of what to do next.
Thanks
  • 108 Answers
Better you unsinstall and then reinstall the Printer software.
Posted on Feb 04, 2008
6ya staff
SOURCE:
How do I do double-sided printing on MFC-240C?
Flip the copy over and reinsert into paper tray and then copy the second side of your original. This is not a duplex model.
Jul 14, 2011 | Brother MFC 240C All-In-One InkJet Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
I replaced all the ink and my brother mfc 240 still wont print black, or copy black, or test print black
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Mar 24, 2009 | Brother Multi-Function Center MFC-240C...
Incomplete scanning and copying
is your scanner glass clean?
if not, clean it tells u hell in the user guide
Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Priting with the brother
Well when you want to print more than one page push CTRL+P
then if u got more than one printer installed choose your printer in the top well to print more than one i think in the bottom it says number of copies then choose how many then print.
Aug 09, 2008 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C stopped copying. LCD showed: check Users Guide & Manuel Troubleshooting & routine mainteance. Print unable 51
This could be to several reasons:
a camshaft could be broken
purge station in disorder
ph not in correct position
Here are some clues:
pull papertray out and turn the paperfeeder by hand several times.
Open printer:
http://www.fixya.com/support/t475349-brother_print_unable_50_error
open printer and check encoder strip (foil runing parallel to ph traveling direction). Is it in right position going thru the ph carrier?
Turn one of the big lefthandside gearwheels several times by hand
Apr 04, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
