Question about Dell Inspiron 6000 Notebook
Usb problem null
  • 108 Answers
You could reformat and reinstall the Windows XP home and then update it from Windows update under custom search and then by selecting the hardware updates. Alternatively you can visit dell site for hardware update directly. Your problem will be solved.
Posted on Feb 04, 2008
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Can't get null modem usb to 9 pin cable to transmit designs to machine.
First, to transmit to your machine using a USB to serial converter, it should have a FTDI chip. Second, you should be transmitting on Com 1 or 2 -- preferably Com1. You can change the port it transmits on in the Device Manager in computer properties on your computer. Third, check on your machine which port it's looking for -- they must match.
Sep 29, 2015 | Singer Quantum XL-5000 Computerized Sewing...
Mysql> desc contact_info -> ; --------------
Hi David,
It looks like you're missing two more null's in the third record, the column count is only 21 and you have 23 fields in your destination table.
All your data matches up to the columns, but you'll need to insert ", null, null" before the last paren to cover CompanyURL and companyPhone):
('Karson', 'B', 'Campbell', null, 'Dr.', 'Chief Resident', 'Pediatrics', '', null, null, '585-544-1212', 'home', '1955-01-05', 'Wife: Molly Kids: Cassidy, Justine, and Cory.', 'Mountain View Hospital', null, null, null, null, null, null, null, null, null, null )
Sep 06, 2013 | Sun MySQL
When i plug my usb keyboard it doesn't work
Assuming the keyboard is in working order, you need to check other USB ports.
Then, getting into the setup menu on startup, be sure that the legacy USB function is set to "enabled"
var fctb_tool=null; function FCTB_Init_db4814f107004376968433ca64c76ffe(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d5e5d4832a6e41c49ae8b74084d24c40(t) { fctb_tool=t; start(fctb_tool); }
Feb 05, 2011 | Compaq Presario 5000 PC Desktop
How to download music onto usb
When downloading music, you normally save it to your hard drive. Then you can copy it from the hard drive to the USB drive. Just use copy and paste. var fctb_tool=null; function FCTB_Init_565da20502c2462dbcd9bb99859b321e(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_be9da42caa7f42999179ad5cc596d2b6(t) { fctb_tool=t; start(fctb_tool); }
Jan 15, 2011 | Shuttle XPC SD32G2 Barebone
I have a wireless keyboard and mouse and I can't type anything I changed the batteries and its acting like it has no power, nothing is working on the key board but the mouse is working. Thanks Tate
1) make sure your batteries are inserted correctly
2) make sure when you insert the USB sending unit into a port that the USB port is working
3) press the connect button on the sending unit and also the connect buttons on the bottom of the keyboard and mouse.
3) make sure in the system setup that USB is enabled.
var fctb_tool=null; function FCTB_Init_7207035e866d4ce295e256df09c8897a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_9fd4111ba11a4016a30810809c03e786(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from and
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
Problem resetting senao 3220
It all depends how your cable is wired. I had to add a null modem adapter and a gender changer to the USB-to-serial cable I bought for this task before I could communicate with the radio. I suggest you try the null modem to see if that is your issue.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Dell Inspiron 6000 Notebook Logo
87 people viewed this question
Alun Cox
