Six months ago my fridge stopped working so I unplugged it and waited for the ice to melt. So I plugged it back in and it started working again, but I have to set it at 3 to reach the food zone. The same problem has started again, ice is building up on the freezer vents and stopped working. What is causing the problem? Thank You.
I believe it is time to change the defrost timer and check the remaining major parts of the defrost system. I will give you a page to go to where you can view theses parts and enlarge them to help you see what we need to start with. (defrost timer). Part WR9X502 Defrost Thermostat part WR50X10025 and the defrost heater WR51X10038 Now this is parts for the model listed above your post right? BRB, Sea Breeze
The first 4 photos top of thst page are related to your refrigerator. If you change the defrost heater please change the defrost thermostat also. Click Here=> Sea Breeze Appliance Parts click on photos if you want to enlarge and part to order or go to my Home page here=> Sea Breeze Appliance Parts and Technical Services If you should need me you may find me here at Fixya or here=> Appliance 911 If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
I forgot to add this photo, Sorry=> WR50X10025 Defrost Thermostat
I also forgot to mention that when there is less defrost the moisture is not carried out the defrost drain tube and then dsometimes that will cause symtoms like this but you would also see ice aon back wall and floor of the freezer, You have have this all done and taken care of, If I don't hear from you again I hope at the least I was helpful, Thanks, Sea Breeze
SOURCE: Freezer vents are building up ice.
A couple of things can cause this problem. One is that your defrost temp sensor is ot functioning correctly and terminating the defrost cycle early allowing ice build up to occur over time. The other thing could be that you have a torrn or loose door seal on either your freezer or your food section door. The thrird possibility is that you deftost timer is intermittent and only working part of the time or is clocking forward at a very slow rate. You can unplug the unit again and place a fan blowing into the freezer section for about 2 hours but we both know this is only a temporary situation and that you should have your unit serviced. I would call for that service either before you defrost it or 2 weeks after you defrost it.
