Question about Seagate (ST3160827AS) 160 GB Hard Drive
Hard drive problem
Sir, when i was reloading xp, the hard disk stopped working. when the system restarted ,system is unable to enter into BIOS settings also.i replaced it. It happened with second hard disk also. what is the problem ? the other hard disk is working properly. will the problem arises in the future?
  • 449 Answers
There is no problem on the hard disk.. It's either the memory or the motherboard is having a fault. Try cleaning the memory contact point with a pencil eraser and try again....
Check also the voltage of the battery cell on your motherboard it should read higher than 2.8V DC, replace it if below 2.8.
Hoping a Fixya result on my suggestion... Anyway, post me back if nothing happens, we will fix it...
Posted on Apr 02, 2008
Hai sir my name thameem my pc is very slow iwhat i solution with me
Posted on Mar 04, 2008
  • 749 Answers
Posted on Feb 04, 2008
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
I am unable to format my 40 GB Hard Disk (samsung) with WinXP Installation CD. After Doing Patition and format it comes unable to format
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Aug 06, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Cant get computer to reload xp after new drive installation
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
Feb 22, 2011 | Maxtor Hard Drive
Need to reload program to operate Hard drive
if you mean operating system program
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 11, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
When I start it it says operating system not found, and stops loading!
When you start it up press f2 to enter bios. Go into boot configuration. Make sure the boot order is:
1. A:/ (floppy)
2. D:/ (cd drive)
3. C:/ (hard drive)
If the boot order is correct make sure your bios are registering your hard drive. If it's not then replace the hard drive. If it is then reformat and re-install the operating system.
Aug 16, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Stop 0x0000007b (0xF78A6528, 0xC0000034,
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
May 14, 2010 | Microsoft Windows XP Professional for PC
Unable to install Xp on Hp Pavilion dv2000
Go to the BIOS setup, & change the disk controller setting from AHCI to IDE. might worth the try. Some Laptops don't have option of SCSI or IDE. But there are SATA Enable/Disable option. Try disabling SATA.
Jun 25, 2009 | Computers & Internet
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Ntldr is missing
seems your MBR is damage. but you can repair it if only you can boot in windows cd and entering in the recovery console.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type this commands one at a time.
FIXMBR  C:
FIXBOOT  C:
COPY [CDDRIVE]:\I386\NTLDR  C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM  C:\
BOOTCFG  /rebuild
6.    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
no warranty...you use on your own risk :)
Oct 27, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
44 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
