Problem for Freezers
Generic problem for all Freezers
I left the Freezer door open and now it see...
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things.
It has been 5-6 hours since it has been closed.
Is it just taking a long time to completely cold or broken?
Model number is Hotpoint HSS25IFMC WW.
Is there any reset button?
Thank you.
Comments:
Jan 06, 2010
- Thank you for your reply!
I put the warm water last night and now it is cold but nothing is frozen.
It has been 17 hours since it has been closed.
What can I do?Jan 07, 2010
- Thank you so much for your help.
I just took everything out from the freezer and defrost and set the temp dial to 5.
It is empty now and just put the ice thing to see how it is tomorrow.
Hope this works!
I will keep you posted.Jan 07, 2010
- It is in the morning and the it is just cold but not frozen...
We have to cal the tech...
Thank you.Jan 08, 2010
- Thank you! Very kind of you.
Best Solution
posted on Jan 06, 2010
Rank: Guru
Rating: 90%, 56 votes
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Comments:
Jan 06, 2010
- You might have to start at square one. Pull everything out of the freezer, defrost the freezer manually. Put food back in the freezer and set the temp dial where you know it worked before. Leave the freezer door closed again overnight and check in the morning. If your food is not frozen you will have to call in a refrigeration tech to check the compressor and controls out.Jan 08, 2010
- I'm sorry to hear that. I certainly hope it is something simple and inexpensive for you. Best regards, Marvin
Was this helpful?1 person thought this was helpful
Asker's Testimonial
Thank you for your help!!!!
" - komatta
Popular Solutions for Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
1 Solution
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
1 Solution
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
1 Solution
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis...
2 Solutions
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
1 Solution
Questions and Unsolved Problems for Freezers
Any opinions on Frigidaire frost free upright freezers?
Posted. Thank You!
I would like to purchase a small frost-free chest freezer. I can only find the manual defrost type...
(More)
(More)
I would like to purchase a small frost-free chest freezer. I can only find the manual defrost type in small sizes.
Posted. Thank You!
spring came out on ice maker flap and i want to put it back
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
my zanussi frost free freezer, about ten yrs old, keeps frosting up and causing fan to be very...
(More)
(More)
my zanussi frost free freezer, about ten yrs old, keeps frosting up and causing fan to be very noisy. How can i solve this?
Posted. Thank You!
I have no manual. Battery was installed when \i got freezer and now needs changing.
Posted. Thank You!
