How to fix a stuck shredder
Paper appears clogged in one 1/2 inch section of schredder
  • 1 more comment
  • jpgund Mar 19, 2008
    I did have to use a pair of hemostats to get the paper out (husband's pliers not thin enough) so nurse Judy to the rescue! And my local hardware store had oil in smaller than 1 quart. Thanks.
  • Anonymous Aug 06, 2008
    I have a GBC 1150X with the same problem. The same small area gets paper wrapped around the core. GBC said it's the stripper unit that needs replacing but that costs more than to buy a new unit. I put a piece of tape across the area so paper won't feed into that spot for now, but I'm buying another shredder.
  • regim Apr 30, 2009
    Your solution with the oil is a very bad idea. I saturated paper with 3-1 and tried to get it to go through the center of the shredder where it is clogged. The side are not clogged. Well, the oil literally exploded.
    I had my face down to the shredder but thank God my hand was in front of my face.
    The explosion was as loud as a fire cracker. It burnt my hair and I have a huge blister on my hand.
  • 168 Answers
Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
Hopefully your shredder will be unclogged by this time.
Hope this helps.
Good luck.
Posted on Feb 06, 2008
6ya staff
SOURCE:
How do you removed jam paper in the schredder
1) pull what you can of the jammed paper out. Make sure the shredder is unplugged whenever trying to work on or in the unit.
2) Then liberally soak the remaining jam with shredder oil and let it sit for 15-20minutes.
3) Try to pull out what you can again. Use tweezers or pliers if available.
4) Then first start the shredder in reverse and then alternate for a few seconds between forward and reverse.
5) If it is still jammed repeat all of the steps as necessary.
Mar 09, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
The schredder runs backward, but forward does not.
Take care, because this thing can also shred your fingers.
Remove the plug from the outlet and try to remove the paper under the rolls. Us a tool, not your fingers. It even would be better, if you could put the top upside down, so you could see where the bulk of paper is clothing the wheels and the sensor.
I think you already emptied the bag under the shredder, because the paper full sensor also prevents the shredder from running forwards.
Jun 16, 2014 | Intimus 421 SE Shredder
Intimus 669-4S Shredder goes into reverse prematurely
After you open the top cover of schredder you will se the condensator. Its 8uf. Replace it and your problem will be resolved.
Mar 04, 2013 | Office Equipment & Supplies
I would like to know how to oil an Wilson-Jones 1250 schredder.
Wow, a name from the past.... with any shredder the easiest way to "oil it" is just to put a bead of oil in an "S" pattern down a sheet of paper to be shredded and then shred the sheet of paper.
If you shred a lot you should do this more frequently...if its only occassional shredding OR if its a strip cut shredder then you don't have to do this as often.
Jun 16, 2011 | Office Equipment & Supplies
My embassy schredder won't work although the light is on what should i do? is there some way maybe i can oil it or something because it's not clogged up or anything? what to do?
  • Cross cut shredders require more frequent oiling versus the straight strip shredders. The more paper and use it gets the more oil it requires. A good rule of thumb is to oil the machine each time you change the bag.
  • Use only shredder oil designed for the specific brand of paper shredder you have. Manufacturers design paper shredder oils to be heat tolerant for the cylinders and blades, and they calibrate them specifically for their machines.
  • Spray, squirt or run a bead of oil across the blade opening. It shouldn't take more than a second or two to reach from one end to the other. Any more than that may result in too much oil applied. Quicker than that means there isn't enough oil to adequately lubricate the machine.
  • Turn the paper shredder to "Manual" and run the gears in reverse for a few seconds, then turn the shredder on "Forward" or "Standard" mode. This ensures that you distribute the oil throughout the machine, and going in reverse first forces some of the dripping oil back up, and then the forward moving blades push it back through the gears.
  • Oil a sheet of paper rather than the machine. Don't just run a bead of oil across the bottom of the sheet because the paper soaks up the oil and the oil may not reach all of the necessary parts. Instead, spray the whole sheet, or run a zigzag line across the paper and immediately send it through the shredder tooil it.
  • Dec 31, 2010 | Office Equipment & Supplies
    Paper is not schreddering
    Do the shredding blades turn??? If the motor runs but the blades dont turn then you have probably lost a gear. If the motor dosnt run in the forward direction you may have lost the PCB.
    Once you can be more specific you can contact Royal at 1-800-524-0799 for parts assistance.
    Nov 30, 2010 | Royal 160MX Shredder
    Wont turn on
    Most probably the safety switch is preventing it from turning on.
    Try neatly and firmly closing the paper basket door/opening; see if any paper bits got stuck somewhere, preventing the switch from being deactivated.
    Jul 08, 2010 | Royal SC180MX Shredder
    Where do i get replacement gears for this schredder?? dertroyit 4002 thanks
    I have a Destroyit 4002 cross cut paper shredder. I have ordered parts twice from shredderparts.com
    Both times they were friendly and sent me the correct parts.
    Jun 12, 2010 | Destroyit 4002 SMC Shredder
    My schredder is jammed. I may haveput too many paged in it.
    The industry trick is to soak the jammed paper with hot soapy water for 2 days.
    Nov 29, 2009 | Office Equipment & Supplies
    get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
    May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
    3,151 people viewed this question
    jasbo
    jasbo
    Ekse
    Marvin
    Marvin
