Question about Hoover AAA160 Front Load Washer
HOOVER AAA160 STUCK DISPLAYING "CONTINUING PROGRAMME"
HI I RECENTLY REPLACED THE WATER PUMP AND WHEN I CONNECTED IT BACK, THE SCREEN DISPLAYED WELCOME... THEN IT WAS STUCK ON "CONTINUING PROGRAMME" AND DOESNT ALLOW ME TO DO NOTHING.
  • asad_attia Feb 04, 2008
    the model number is HOOVER AAA160 - 01. the water doesnt come in because when you turn on the machine, the screen says continuing programme and doesnt allow me to start the washing. any ideas?
  • asad_attia Feb 06, 2008
    hello people. i tried turning off the circuit breaker, checked the pressure switch, any blockages on the pipe, the motor brush. all is fine but today i noticed that the incoming current is ok, but i dont think there is sufficient current going elsewhere such as to the waterpump (only 40v). any ideas?
  • 549 Answers
Have you tried turning off the circuit breaker that supplies power to the machine?
If you try that let the machine sit for a few minutes so it will lose whatever info there is.
Also, did you turn the water back on? It is not a good idea to run the pump unless there is water supplied to it.
What is the model number? I may be able to find troublehooting info for you.
Posted on Feb 04, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 07, 2008
    did you check to see if the motor is wired exactly the same?
    Is it a reversible motor(are there more than 3 wires in the box where it is connected?
    It seems like if you have 40v getting to the motor, that something is causing a voltage drop, unless the nametag on the motor says it is a 40v motor, which is doubtful. you should have 120v at the motor.
Sticking programme
This could be a problem with the controller as it is not waiting for water to warm before continuing.
Water element should be checked, as well as the water thermostat switch (which may be stuck on), possibly a substitute timer fitted to make sure you replace the right part.
Jun 06, 2010 | Neff 24 in. S4443 Built-in Dishwasher
Wash programme will not start
If your machine will not start or complete the programme..
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
Jan 18, 2010 | Hoover AAA160 Front Load Washer
Hoover HNL 6166 6kg A+AA 1600 washing machine....smell of burning like burnt rubbber...........
Hi.
It is very likely you need to replace the motor brushes. These are the electrical conections in the motor that wear after a time. They are fairly cheap, uses-replaceable, and available from online appliance specialists.
Turn off water and unplug before removing top/ back pannel to access motor. ***** CHECK MOTOR TYPE BEFORE ORDERING PARTS ******
Sep 30, 2009 | Hoover AAA160 Front Load Washer
Stops halfway through wash cycle
be sure that BOTH water hoses are on and providing water. Your description sounds like typical situation: Dad gets water bill and freeks out, turns off hot water to laundry...SOOOO, when the laundry needs THAT hose, it just stops and waits ...if no water, no go..
Doc
Sep 18, 2009 | Hoover AAA160 Front Load Washer
The drum of my washing machine is not turning with the programme
Check belt is not broken, by taking off the back plate at the back of the washer
Sep 05, 2009 | Hoover AAA160 Front Load Washer
Error 03
water drain problem (check drain hose and pump)
Jul 30, 2009 | Hoover AAA160 Front Load Washer
AAA160 Washing Machine
yes most certainly, with leaks it is either the seals or cracks in hoses or rust holes in wash cylinder, but most likely the first too because of being a fairly new model
Jul 01, 2009 | Hoover AAA160 Front Load Washer
How to cancel pragram after wash has started
hold the start button in until disply shows programme cancelled - it'll come after programme paused just don't let go or it'll only pause
Dec 20, 2008 | Hoover AAA160 Front Load Washer
Washing machine was running and stop inbetween rinse cycle and water pump got spoiled ihave already replaced with new pump but it is stuck on continuing programme and do not function at all. it only...
There's no way to properly help anyone with "Generic problem for all Washing Machines" as a topic heading. When posting problems please be more specific. Provide a clearly worded problem including the complete model number
Feb 07, 2008 | Washing Machines
Hoover AAA160 Front Load Washer Logo
131 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
