Clothes don't dry completely
Check your breaker. An electric dryer works on 220 volts, which is two 110 volts put together, but on separate lines. Those breakers have to be separated all the way from the transformer. So, if you have one breaker for the dryer, you will be okay, usually on a double pole, double throw breaker. Sometimes they are wired into two different breakers. The motor is on one breaker, and the heating element is on the other breaker. So, if they aren't on a breaker that is made as a double unit, the heating element can trip one breaker, and since they aren't made together as a unit where it will shut the whole dryer down, the motor in the dryer will still run, and the drum will still turn. It just won't dry clothes. Now, if you have made sure your power is ok, which i have no way of knowing if you just moved there, you had the dryer working in that spot for fifteen years, or what. So, if you have had it there for a while and it runs and it does not dry, and the breakers aren't tripped, then you need a new heating coil in the dryer. They burn out, just like toasters go bad, they work on the same principle. It is not that hard to replace one, just look at how the old one is before you remove it, and install the new one in the same way.
