Question about Nokia N95 Cellular Phone
Nokia n95 freezing
I have nokia n95 and when i turn it on it freezes at the nokia logo. you then have to take out the battery to turn off the phone. it totally locks up the phone.
  • 1 more comment
  • babyboii Mar 20, 2008
    hi i have the same problem with u got that when i turn the phone on and it stop on the logo screen i take the battery out and put it back still the same how can i fix that plzzzzz help me thank alot
  • Anonymous Mar 24, 2014
    My phone cant function if its not in a charger, if it does its only for a few mins. When I try turning it on, it just shows the apple logo, freezes and then goes off.
  • Anonymous Mar 30, 2014
    my nokia x stuck on nokia logo and wont go pass the nokia logo on boot..when i pull out the battery and put it back and turn on the phone its still the same..help meeee
    President:
  • 1,017 Answers
If your phone used to work but has stopped because it froze and you took the battery out, to restart it. There's a possibility that it will need a reset to get it going again.
Reset code: *#7780#
But if you just got it, and it has never worked, it might be blocked, by the original owner, (who lost the phone or had it stolen), using the
IMEI (International Mobile Equipment Identity)
in which case you need to take it to a repair shop.
Posted on Feb 04, 2008
My n95-3 turns on but stops at the nokia logo and shuts down and won't charge from what i gather have new battery new charger still no go? so basiclly won't turn on only lights up to nokia logo and turns...
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the "*" button, and the number "3? button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Regards
Egroeg
Mar 24, 2011 | Nokia N95 Cellular Phone
Hello, my nokia N95 works for a few minutes then just goes to a blank white screen saying nokia. It just freezes up. Is this anything to do with the battery?
no battery is not a prob here. ter s no need to change the battery. it may be due to some software problem which may be caused due to storage of too many songs or videos. just give your mobile for service.
Jul 05, 2010 | Nokia N95 Cellular Phone
Nokia N95 keeps freezing. I have to keep taking battery our and restarting.
Have you tried updating the firmware ?
Check this link on the Nokia website to get the correct software for your phone.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
Feb 12, 2010 | Nokia N95 Cellular Phone
My N97 freezed on the Nokia logo, cant reach the sim code display
THE BEST WAY I FOUND IS TO HARD RESET IT AND THEN RESTORE MY CONTACTS SAVED ON MY MEMORY CARD !!!!
IT SUX I KNOW BUT IS THE ONLY FREAKIN WAY TO TURN MY N97 **** ON BACK AGAIN
Jan 13, 2010 | Nokia N97 Cell Phone
Nokia N95 8G - freezes when you turn it on and you can't go past the NOKIA welcome screen. Tried taking the battery out, charging it, etc.
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 29, 2009 | Nokia N95 Cellular Phone
Nokia N95 8GB , freezes when turned on
I think that maybe the software (symbian S60) may be corrupt on your phone.
Hopefully all of your contacts, etc are backed up as i think you may have to do a hard reset.
To do this type *#7370#.
The phone will re-start and it will be returned to its original factory shipped state.
I hope this helps.
Jul 08, 2009 | Nokia N95 Cellular Phone
My nokia n95 keeps freezing alot keep freezing while using the GPS or sometime w/o any sw running
When you run apps and use web especially when watching online videos, ram of your n95 quickly start ending.When the ram completely finishes, your phone freezes and reboot.So you should continuously clear private data while browsing and don't run more than one software at a time so you can save the ram.
Mar 31, 2009 | Nokia N95 Cellular Phone
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
Won't Turn On
hi there jg3arrow hope this will work for you. maybe its a software problem
here's the tricks:
backup contacts first. then
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Apr 09, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
677 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
