Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Water freezing I also have a problem with the water freezing in the door and fresh fruit section. A repair man just came and said it was the part at the top of the refrigerator that basically does not allow the refrigerator to shut off-something with the fan. He also wants to replace the water tank because they apparently crack and can leak after they thaw out. I can recall that the price for the water tank was 42.00. I just looked it up on line and I can purchase that part for 18.00 at just the first place I looked. My question is what is the name of the part that he said was the section in the top of the refrigerator and can it be repaired by a novice? My husband can do just about anything (electrical excluded) and we have been hit with so many large expenses lately. The total to fix our refrigerator was going to be about $286.00. Ouch! What do you think?
  • 1 more comment
  • Linda Russ Feb 04, 2008
    I decided to attempt to test this myself rather than wait for my husband. I removed the sheild and light bulb, held all temp buttons down until they flashed, pushed the filter reset button and looked up into the little box area. I saw no movement of anything. I could hear a fan noises but again saw no movement of any object in the area you told me to look at. Does this mean the door is staying open and that is why the refrig. is freezing? Sounds right. I attempted to exit the test mode by putting the freezer temp on 1 and the refrigerator temp on 6. Was that what you meant? Also, I think I told you the water tank is frozen. What do I need to do to get that thawed out? The repair man said that should also be replaced because the frezzing can make cracks in the housing and I could end up with a water leak. Is that true? Thank you for your help so far.
    Lelu
    posted by lelu on Feb 04, 2008
    Report abuse
    Comment by lelu, posted on Feb 04, 2008
    Lelu
    I pulled out the drawers and unscrewed the water tank. I could see some water moving in part of the tank. I layed it on its side andput a pan with boiling water on it. within minutes the water started working again. Since the tank did not totally freeze could I assume the tank is not cracked? I am going to take everything out of the refrig and let it defrost. I guess I could tell then if there is a leak. Right now it looks like I just need to order a diffuser. Does that sound right to you?
    Lelu
    Genius:
  • 3,422 Answers
Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
The damper door (DIFFUSER) is located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced.
Replace damper door , with new damper door kit WR17X11508
http://www.repairclinic.com/referral.asp?R=1265&N=1055112.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 04, 2008
  • 1 more comment
  • Priya darshan Feb 04, 2008
    Yes so far u have done everything right..
    And yes since the door is open that is cause of freezing..
    Your technician has cautioned u about the problem that there are chances of water leaking out and it can make cracks..
    Well he is right in that case and i would suggest u to get it fixed by him..
    There is no home remedy for it...
    To fix the water leak u can try doing the below method.
    Try defrosting it, if this doen't work then do the following and ur problem will be solved..
    BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
    Here is another solution:
    inside of freezer, take back cover out and thaw the ice with hair dryer
    or hot water. don't use any sharp tools. When thawed make sure water
    drains through defrost drain.
    I think ur tank is alright..and ur going in the right direction and i hope ur problem gets solved soon..
How do I freeze freash peaches
You cant, its a soft fruit, so when the water molacules freeze they split and ruin the fruit
Sep 16, 2014 | Refrigerators
Does my fridge have a defrost timer? The first time the fridge quit working we had a repair person come figure out. He found the circulation fan was frozen in the back panel inside the fridge. He turned...
This is a very common problem with Samsung refrigerators especially the type that has two evaporators. The evaporator that is inside the fresh food section and will usally give people the most problems. The drain below the evaporator in the fresh food section will begin to freeze over or become blocked by gunk inside the drain line. When this happens it causes the fresh food section to retain water because with the drain blocked the moisture and defrost condensate water now have nowhere to go. Once that drain is blocked the freezing over of the evaporator will begin to happen more often slowing down defrost which again make problems worse. Clean the drain, make sure the refrigerator is level and confirm the model number of your refrigerator. Your model has no defrost timer and defrost are determined by the motherboard. There is a way to force defrost with your model from the motherboard but until the drain is cleaned out defrost will not help much because the water has no where to go but to freeze over the evaporator and fan area of the fresh food section evaporator. Is your model the?=>RF267AERS I am here if you have questions, Sea Breeze
RF267AERS Parts
Oct 21, 2013 | Samsung RF267AERS French Door Refrigerator
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
Door water dispenser does not work
If the fresh food section is not too cold and freezing the water in your fresh food section water storage tank I want you to check the dual water control valve. Parts detail can be found on page 7 of your Click Here=> MFI2568AES Parts Manual Item number 15 is the 67006322 Dual Water Control Valve
If you would like a user manual please go here=> Whirlpool Manuals and Guides and enter your model number. I will be here should you have questions, Thanks Sea Breeze
Nov 08, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
My fruit and vegetable drawers keep freezing my fruits and vegetables. What could be causing this to occur?
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
Oct 31, 2010 | Refrigerators
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Some fruits and vegs freeze in drawers, but not all
GE fidge it is a common problem...air dampers stuck wide open..too much cold air going to fresh food side from the freezer..you need to call repair man
!!! but if you still want to do repair by yourself, send me model number i send you some ideas and most important some images...so you can put everything back together after you done :)))
totalcarefl@yahoo.com
Aug 29, 2009 | GE Refrigerators
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
3,841 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
