Question about Sony SRF-M10 FM Radio
Setting preset radio stations
I have the little arm-band radio, its blue with earphones that u can wear on your arm. I forgot how to set stations. It is possible, did it before but now don't have the directions. There's a preset button a memory button and then the tune up and tun dn button, Can u help?
Thanks.
  • Rosamarta Mar 11, 2008
    I do not understand how to store stations in memory works, can someone suggest a solution please?
  • mag003 Mar 28, 2008
    I am haveing the same problem setting stations. The radio will continue to scan stations. Neither the set or reset buttons will stop the scan. I have also tried holding down the scan button but that also failed. Can anyone help???
Hallo, I had the same problem and found following solution: first search the station you want to preset. Than put the the little round button below on the right side called enter/time and on the same time the button of the number of the memory preset you change.This number will appear in the display an remain the preset. Sorry about my English - I hope you understand however.
Posted on Apr 14, 2008
The rocker button on the side at the top is the one that changes channel, if you press the button beneath it, once, you can then use the rocker button to find new channels, when you find one, press the rocker button in once (at the centre), then rock it up or down to set the station to whatever position you want it. Once thats done you have to start all over again for every channel.
Posted on Apr 30, 2008
6ya staff
SOURCE:
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
Mar 03, 2011 | Alpine CDE-7853
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
How to preset stations
Hold down the numbered keys to set a preset. Just press them when you want to go to that station. Holding "1" sets preset 1. You can also change your band to have 10 presets on band A, B, C (some radios have more bands).
Dec 29, 2010 | Audio Players & Recorders
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
JVC RX 809V home reciever
Most times it goes like this:
find your station by manually searching the frequency. When found, press the memory button and in your display the word memory will flash. than press the number you want it stored under and hold it pressed untill the flashing stops.
Other option:
once station is selected, press the preset number and hold it untill you hear a beep or, if the number flashes on your display, it stops flashing.
often you have the possibility to store aprx 10 presets on 1 band, by seleting the band you get new presets for each band, geeting in total 40 preset possibilities.
Let me know if this solved your problem.
Aug 08, 2008 | Audio Players & Recorders
Sony SRF-M10 FM Radio Logo
263 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
