Question about Ecoquest Fresh Air Air Purifier
How to remove the fan blade ?
We have had the unit for several years and the fan is getting slow to restart after the machine is off. It runs fine after it gets to going, so think the fan may need to be oiled but we are not sure how to get the fan off without damaging it. Any ideas?
  • 4 Answers
080204 FixUp EQ air blog remarks
To remove fan blade you need to obtain a thin strong probe, such as a Scratch Awl for wood, that will fit without binding, into the cruciform spaces around the plastic collar. Gently insert into space of plastic collar and lever against the spring metal retaining clamp; getting started may require a bit of force, so be careful to adjust and gauge your efforts. The process is to move clamp in small increments, one side then the other, up the collar until clamp is free to remove.
The collar will still be tight, so if you can form your hands into a gear puller form with your finger tips between the fan blades under to the solid portion of the fan ring, pushing thumbs against the Spindle and lifting in as quick a jerk as you can manage to get it moving. Once moving it should be removed easily enough.
The electric motors have two bearing surfaces, one front one back. Both need to be addressed.
I like Breakfree or similar that acts like minor solvent / major lubricator with good thermal properties. The solvent aspect helps clean out unwanted particles and/or old dried lube. The new lubrication is heavy enough to hold up for at least a year; so yearly checking should be scheduled.
On other brands with heavier motors, I've tried greases when I've stripped down the motors even further. So far I've discovered a heavier lube can be hard on start up and need more time at slower speeds until unit warms up.
Something like WD40 is good for penetration and flushing, but IMO too light for sustained duty. There is a lot of spinning and heat over a year's time.
I just torn down a couple of F1's. They've been doing well for a couple of years. But with all air filters/ purifiers, they REQUIRE periodic maintenance. [Had my biggest laugh reading complaints about Oreck air filters; people NEVER cleaned them and complained when they failed.]
Yes, all these small electrical motors will eventually need lubrication, I recommend before 2 years, as one of mine had a frozen (lack of lube) motor in that time.
If you get into the back to try to get at the rear bearing, you may find that you might be considering a more thorough cleaning (I noticed a bit of corrosion). If you do and if that means taking more stuff apart to clean, be well advised of the time involved and the number of wires needing displacement, especially the electronic wire connectors at the front to the circuit board.
So, get a digital camera and take clear pictures (and check them!) Before and During take apart as well as a couple of paper notes about wire runs and placement. I have even used paint pens to letter/number info to the unit.
Posted on Feb 05, 2008
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
I have two ecoquest breeze and they are both around four years old. One just quit working, meaning the fan will not turn, the lights are still on, the other one the lights are all lit up but I cannot...
For the fan:
1) Unplug the machine
2) Remove the front grid.
3) Firmly but carefully pull the fan blades off of the shaft, holding toward the center of the fan, not the blades.
4) Use a light household oil (3-in-1, sewing machine, hair clipper) and put a drop or two on the shaft while you turn it manually. Do this until you feel the shaft moving easily.
5) Leaving the front of the machine open, turn it on and see if the shaft turns. If it doesn't, unplug it again, and continue working small amounts of oil down the shaft and then seeing if it turns.
6) Replace the fan. Turn the machine on, and give the fan a spin if it doesn't turn on immediately.
That should do it for that machine!
The other machine may be set on "Sanitize." This means that it will run at top capacity for 2 hours. Push the "Sanitize" button to deactivate it, then adjust the controls for daily operation. If this doesn't solve the problem, the issue is most likely with the computer system itself, and we can't do anything about that! Unfortunately, Vollara (new name for EcoQuest) no longer services or sells the Breeze. However, there are some options for upgrades and/or trade-ins. Call Customer service (800-989-2299) for options. Use #16618 if you need a referral number.
Jan 17, 2011 | Ecoquest Breeze AT Living Air Purifier
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
If you need to replace the fan motor, the fan blade can be removed by grasphing the center hub of the fan and pull the fan straight out of the purifier. I remove it every time I clean my machine, since it easy to clean it once it is removed.
Nov 21, 2009 | Ecoquest Fresh Air Air Purifier
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oct 30, 2009 | Oreck Console Air Purifier
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Jan 12, 2008 | Ecoquest Fresh Air Air Purifier
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ecoquest Fresh Air Air Purifier Logo
292 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
