Panasonic 27 Picture shrinks at top and bottom of screen.Sometimes a line will run across screen. Once in awhile picture returns to normal
  • katenate01 Feb 04, 2008
    banged outside of set with hand and this seems to correct problem.Thank you
    Brigadier General:
  • 6,966 Answers
Initially I would suspect a problem in the Vertical section of the TV. This could either be the capacitor or the IC itself. In some instances, there are no component failures but rather cold solder joints.
Based on your post/description of :...Once in awhile picture returns to normal...", I am more inclined to think that it is a case of cold solder. which can easily be corrected by reapplying heat on the IC pins or the other associated/nearby components with the use of a soldering iron. Care must be exercised since TV units still pack high voltages even when off and unplug.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
  • Louie  Role
    Louie Role Feb 04, 2008
    Banging made it worked just confirms the cold solder connection. Soon as the unit runs for some time and heats up, problem will recur.
    Nonetheless, am glad that it works.
    Cheers.
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
27" flat screen
The main cause of this problem is cracked solder joints on the vertical output IC. Re-flowing the solder should take care of it. Sometimes a capacitor (normally against the heat sink containing the vertical output) will cause this, but, it usually has a different symptom. The price of repair will normally run, depending on where you live, $100.00 to $130.00. It's a small job and is done quickly. Hope this helps.
Mar 17, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
