Question about DFI /LAN PARTY NFORCE4 ULTRA-D/ Motherboard
Dual chanel problem
First problem - I cant get my 512mb sticks to work dual chanel - pc reboots before the system loads up.
Second problem - if I put four 512mb sticks (all same specs) at the same time I have a black screen and a beeping pc.
What to do, what to do?
  • shalick Feb 04, 2008
    It seems, that one of the slots on the board is broken, since the pc crashes whenever I try to put any stick in that vary slot :/
    President:
  • 2,351 Answers
The beeps your hearing are known as bios beeps. They are telling you there is a problem with your memory. On your board the four dimm slots are split into two groups. A & B. Pg. 19 of your manual. Please read Pg. 21. Remove all your memory & put only two of your 512 Dimms into slot 1 & slot 3. Boot the Pc. Notice any beeps? Check your boot screen to see if bios sees the current memory as matched memory. Shut the Pc down & remove memory, replace with the other 2 Dimms in the same slots. Boot Pc. Again check to see if memory is being seen as matched memory & no beeps. Are you getting the idea here. What we are doing is trying to find which if any dimms may have a problem & which dimms work in which channel. Increase in size to 3 dimms or 1.5Gb in memory till you find a working order with no beeps. If you think 1 or more dimms may be faulty download a free test program called -Memtest86 at this link.
http://www.memtest.org/ Scroll down till you see - ** Memtest86+ V1.70 (01/14/2007) ** all typed in red. Here you can choose what type of bootable file you want. An iso or a zip. You can creat a bootable floppy or a bootable CD.
This should help. If you have trouble & need more information please post back.
Posted on Feb 04, 2008
  • Mike Peluso
    Mike Peluso Feb 05, 2008
    I do not doubt your conclusion but if you take a very strong flash light & include the help of a magnifying glass you can double check that slot for any bent copper connectors. You may even find some lint or dust built up deep within. Take a lint free cloth & add a wee bit of Alcohol & wipe down the copper leads on the dimm. Than do the same with a cotton swab into the slot. Blast it dry with some canned air. Make sure both dimms & slot is dry before reinserting memory. Try again. This may help!
    map9966
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
Why can not I connect to the Dual chanel memory in the GA-K8NF-9
Supports Dual Channel DDR400 memory architecture. And up to 3 gb support in winxp32 bit. 4 gb support in winxp64 bit.
Dec 11, 2009 | Gigabyte GA-K8NF-9 (890552602964)...
I have no idea in overclocking my PC
Download AMD Overdrive here
It is a powerful all-in-one overclocking, monitoring, and testing utility designed for users of motherboards with AMD 700-series chipsets.
Mar 11, 2009 | MSI 6600GT 128M VIVO/TV/DVI OVERCLOCKING...
Upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Jan 14, 2009 | Biostar GEFORCE 6100-M9 Motherboard
I can't find the Timing for Crucial PC3200 DDR 400mhz
Sorry to run dual channel memory both stick MUST be the same
Aug 19, 2008 | Intel Motherboard
EPoX EP-8RDA+ Pro problem with memory
First try setting your memory voltage in the motherboard bios to 2.5volts if you haven't already and you might try different timings in the bios also for example 3-3-3-8. If that doesn't work try taking out one of the modules and testing them each by themselves in the memory slots of your motherboard. It may take awhile, but you'll rule out the memory slots causing the problem. One of the memory sticks could be faulty. Hope this helps.
Jul 17, 2008 | EPoX EP-8RDA+ Pro Motherboard
Dual Core
if the dual core was shut down when xp loaded (installed) it would crash when trying to run two cores.
Apr 30, 2008 | Toshiba Satellite A105-S4074 Notebook
Asus K8N-dl - second processor present but not running...
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
Aug 04, 2007 | ASUS K8N-DL Motherboard
Computers & Internet Logo
74 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
jason
RajDeep Gautam
RajDeep Gautam
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
