Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother DCP135C All in One Printer
I purchased the above printer and I inset the disk and run the programme. When I tried to print using the file printe menu it doesn't show up the printer location. Is it possible to tell me what I have done wrong?
  • Anonymous May 03, 2009
    cannot install the DCP-135 on a Mac Powerbook running Tiger
  • 832 Answers
Do you run XP or Vista or Mac? And do you run a mfc440 or a dcp 135?
Anyway, in case you run Vista there are some new drivers avaiable:
http://welcome.solutions.brother.com/bsc/Public_s/index.html
(choose your country and enter your machine (e.g. dcp or mfc XYZ) have a look at the faq, too.
Posted on Feb 04, 2008
If you are using XP just add a printer in the controle panal and select the others optshion and select the CD and the drivers will install make sure you enable the drivers in the hardware manager aswel under hardware in control panal
Posted on Jun 09, 2008
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP135C downloaded driver in English but when looking in printing preferences it's in German. How can this be changed? I have reinstalled it 3 times now and also downloaded it from Brother's...
Did you try uninstalling the printer driver and software before reinstalling it? That should remove any printer driver-specific language preference settings. What OS are you using?
I had thought to have you look for Zunge in die Einstellungen menu, but since there is no language setting in the English preferences, there probably will not be any in the German version either.
May 03, 2011 | Brother DCP 130C All-In-One InkJet Printer
LOST INSTALLATION DISC FOR MY BROTHER DCP135C PRINTER HOW CAN I GET ANOTHER ONE
The drivers and software for the Brother DCP-135C 4 IN 1 Flatbed Digital MFC All-In-One InkJet Printer can be downloaded by clicking on download below.
Download
OR use the link provided
http://download.brother.com/welcome/dlf002943/135INST-A.EXE
1.Enter the link provided in the navigation bar
2.And press enter
3.You will get a pop-up screen, select save as to destination you wish to save.
4.After completion install the downloaded file.
I hope this information will be helpful. Thank you for using FixYa!
Jan 31, 2011 | Brother DCP-135C Flatbed Digital MFC...
I never use any colour other than black yet I have to purcgase cyan, magneta, and yellow when my black cartridge is empty. Is it possible to overcome this problem, ? My printer isa DCP135C
You don't have to replace the coloured cartridges if you only use black. But if you print something that is not pure black then it will use the other colors. For expample, if you print on a gray scale, since this is a color printer it will use the colored cartridges to get the gray color. The colored printer will only use the black ink for pure black colours. If you just use black to print, why not use an inkjet printer that just prints black or uses black cartridge. It is available in the market.
Nov 08, 2009 | Brother DCP 115C All-In-One InkJet Printer
When scanning to ocr I get brccMCtl.exe has encountered .... and it shuts down. I can scan to email, file, and image. But Not to OCR. The Brother Control Center 3.00 is the problem.
I deleted all Brother programmes from by PC, cleaned the registry and used the Brother Uninstall programme first. (I restarted the PC after each deletion)
Then I reinstalled the latest Brother printer driver software without the PaperPort SE 11 programme.
Then I installed the Paperport programme separately.
It worked.
Thanks
Oct 26, 2009 | Brother MFC 490cw Color Inkjet...
My Brother DCP135C printer won't read my new cartridges
Do a hard reset on printer to restore factory defaults.
Sep 20, 2017 | Office Equipment & Supplies
Printe paper jam problem for brother dcp135c
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
Hi, i'm trying to set up and install my new brother HL-2140 laser printer using the installation Disk that i recieved with the printer. The problem is that the installation is interupted because it says...
THE FILE IS ON THE DISC......STUPID BROTHER SOFTWARE JUST DO A SEARCH WITH WINDOWS ON THE INSTALL DISC..... OTHERWISE TYPE THIS FILE PATH IN... D:\install\dan\PCL\win2kxpvista
Nov 20, 2008 | Office Equipment & Supplies
Brother dcp135c
dcp 135c printer will not print yellow put 2 new inks in still not working, and sudenly it will not print from my hallmark card program
Aug 21, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
1,811 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
