How to reset UtStarCom W3002G4 modem
Right now Im unable to access teh Modem config web page 192.168.1.1 , it is throwing a page not found error
  • 2 more comments
  • thiraviaraj Nov 19, 2008
    How to reset utstarcom wa3002g4 modem.
  • tcstring Dec 09, 2008
    How to reset UtStarCom W3002G4 modem.........there is no reset button for this modem.....................
    and wlan also not working.................
  • ziyad kv
    ziyad kv Jul 23, 2014
    in the bottom there is round hole in a side apart from square ventilation holes.keep it pressed with a pin for 30 secs.
  • ziyad kv
    postin in this old thread for any one else in need
    Problem Solver:
  • 7 Answers
At the back of the modem, you will find a small reset screw, reset with a pen or a pencil and restart the computer
Posted on Feb 08, 2008
After installing new Hard Drive, modem is not found. Downloaded drivers, modem not found, given error msg: 62 Reseat Modem. How do I do that? Or is there an alternative?
Unplug the power cables, take teh cover off. Remove then reseat the modem card (or riser card if it's an AMR). Replace the cover and reconnect the cables.
Most modems fail due to static (replace teh card) or software ("Device in use" error - uninstall from device manager and reboot)
Dec 03, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I HAVE A DELL DESTOP COMPUTER THAT SENDS CONSTNT ERROR MESSAGES
Hi Laurie,
Either the modem or the Windows Explorer you are using may not be up to the speeds you need in browsing.Is the modem running on 3G speeds[above 3.0MB per sec]?
Change the browser and try another one.
My recommendations:
Both of which are a free download for installation.During setup installations,set the browser[Mozilla/Google]as your default browser.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Computers & Internet
Netgear WPN824 router
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 24, 2010 | NetGear RangeMax WPN824 Router
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
Not able to configure and connect to internet using router
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
May 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Sbg900 setup and login page
I had this problem just last night. I held down the reset button for 20-30 seconds. It worked when after pressing teh button the LEDs stayed on and then after the 20-30 seconds they started to blink indicating the reset. If they do not start reset while holding down the reset, let go and the modem should reset itself. It took me a few times to get this right since teh reset button is rather sensitive and a momentary depression/release will resutl ina reset of the modem but not to default password. I found out I was inadvertantly doing this momentary reset due to teh sensitivity of the switch.
Anyway, next make sure you type "admin" and "motorola" in all lower case. I was using Admin and Motorola - no good.
Nov 21, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Cannont Access Modem
1. click START-settings-Controll Panel- Network Connections
2. right click on your LOCAL AREA CONNECTION and select PROPERTIES from the menu.
3.when properties opens, select TCP/IP by highliting it, then click on the properties .
4.once the new window opens titled "internet protocol (tcp/ip) Properties you will need to check the boxs that say "Obtain an IP adress automatically" and "Obtain DNS server automatically"
5. Click on OK
6.reboot
Hope this helps, post if you need further assistance.
Oct 05, 2008 | Efficient Networks SpeedStream 5100 Modem
Web site connectivity
Can you access msn.com via command prompt?
Mar 18, 2017 | D-Link Computers & Internet
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
3,134 people viewed this question
David Payne
David Payne
