-   I cannot view my CD ROM Drive, It is not even listed in the device manager. I have tried deleting upper and Lower filters in regedit, however, I did not see any filters.-   Guest
Jan 24, 2009
-   I am running a G4 Tower Mac OS 10.3.9 when I try and burn a CD I get erro message X080020025 but I can play music cds Help??
-   cheloe96
Feb 20, 2008
-   I having the same problem.-   Jojosmooth1
Feb 06, 2008
-   Thanks for comment by chandra_anc, posted on Feb 05, 2008. There's a possibility that my problem is of "corrupt driver". Now, how can I reformat or reinstall my system if my optical drive is not working properly? The same situation appears even I replaced the ODD with the good one. Is there any other way that my system disc can be read with other device? Still, thank you so much for your effort & support to my problem.-   Guest
Feb 05, 2008
-   No detection problem in BIOS Utility SET UP & during booting. But there is no CD ROM drive on My Computer. I've done many ways like Device Manager, REGEDIT, System Restore & Driver Update. In Device Manager, there is CD ROM entry with exclamation ( ! ) mark. When I update the driver..."Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)". In REGEDIT, when I click the {4D36E965-E325-11CE-BFC1-08002BE10318} the upper/lower filters didn't appear. System Restore has "no improvements" as well. And it's very difficult to find "Driver Update" support from the manufacturer. I wish someone can provide info to solve my problem. And who knows, may be I can return back something to him/her like a simple "Thank You so much". -   Guest
Is the LED of your CD ROM blinking? If yes then go to device manager by right clicking the My Computer icon and then click the Properties command. In the Properties window select the Hardware tab and then click the device manager. Is the CD ROM entery there! yes> right click and enable the device. If no then reformat your hard disc and reinstall.
In case your CD ROM's LED is not blinking (Rarest case) then simply check all the cables connected to it, atleast the power cable. if it is still not working, your CD ROM got damaged and there is a time to change it.
Comments:
Feb 05, 2008
- The only problem here is of corrupt Driver. It might have gone out of Order by its own or due to some Viruses. The best possible option in less time is that reformat and reinstall your system. Of course, you must take backup your Data on a Flash/Pen Drive before you do so.
I cannot access my Yahoo groups most of the time and when I can and go to use one of the Group...
(More)
I cannot access my Yahoo groups most of the time and when I can and go to use one of the Group functions I get a ''Internet Explorer Cannot Display Webpage''. I have tried the Diagnosis button when I get the message but that does not work and neither does refreshing the page. Yahoo homepage has also been loading slowly but other webpages load just fine. Coly
the buttons at the bottom of the monitor come up as osd locked evrytime I try to access them. How do...
(More)
the buttons at the bottom of the monitor come up as osd locked evrytime I try to access them. How do I unlock?
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the...
(More)
I need to change the coin cell battery in my Dell Latitude 8100, I don't know which panel on the underside to undo to find it.
