Question about Fusion FEW12PK Car Subwoofer
Fitting a sub and a amp
I baught a fusion sub and amp of somebody but theres know instructions could you tell me how to wire it all up please
  • 2 more comments
  • retxab Apr 02, 2008
    how do i fit it all up?
  • Anonymous Oct 16, 2008
    ho do i hook up my fusion amp?
  • Anonymous Mar 04, 2009
    how do i wire up a sub and amp to my car?
  • Anonymous Mar 09, 2009
    1 sheet of paper with a picture of it all wired up but no detailed fitting instructions.
    Bought new.
How do i fit the fusion amp with out the sub
and then to fit the sub in later time???
thanks
Posted on Apr 27, 2008
  • 65 Answers
Is it stolen?
Posted on Feb 08, 2008
Fusion AT 1100 Flashes green power light once and then shuts down. Hiya I have checked all the wires again but no luck. I love this sub and do not have money to buy another one. Please help :-(
Amp is going into protect mide. This means either the amp has an internal fault or the speaker is blown. Pull the speaker out and disconnect the wires from it. Make sure they don't touch. If the amp powers up fine you know the speaker is bad. If it doesn't the amp is bad.
Jul 26, 2016 | Fusion Car Audio & Video
I have a 2 ohm dvc sub and a fusion pp am10001 amp what the best way to wire the sub to this amp
Since your amp is only 2 ohm stable, you will need to wire your 2 ohm DVCs in series (if they are 2 ohms each voice coil). Here is the manual for your amp:
http://www.vbc-group.com/ebay/PP%20Amp%20Man%20Pg1-21.pdf
Jan 09, 2016 | Fusion Car Audio & Video
Why doesn't my Receiver tell my amp to turn on
Ok get a test light and test the remote on the amp and on the back of the radio if it is good in both places then check power and ground
Apr 24, 2014 | Kenwood Remanufactured KDC-HD548U CD...
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
Fusion sub n amp dont work
didi u check ur fuses in the amp..if not there check the fuse under the hood on your power wire.i had the same problem
Jul 27, 2008 | Car Audio & Video
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Help me!!!! i have fitted this sub & amp but how do i fit a 2nd amp for speakers
youll need distribution blocks for second amp.this is the basic solution though.other things like wire guages,amp power and crossover settings need to be considered.
Aug 02, 2007 | Fusion FEW12PK Car Subwoofer
AMPLIFIER PROBS
check all power coming to your amp remote especially
Jan 21, 2007 | Fusion FEW12PK Car Subwoofer
Fusion FEW12PK Car Subwoofer Logo
951 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
