Question about Mitsubishi WS-65809 65" Rear Projection Television
Upgrading my 480 component input to 1080
I was wondering if there is a way to upgrade my 480 inputs to 1080, currently on my ws65869 i only have 1 input for 1080.
    Problem Solver:
  • 10 Answers
I have a similar problem with my Mitsubishi 73" with component only 1080 input. It really hurts knowing the best I can do is 480 DVDs on this system. Do you have any model numbers for converters you would recommend? Ideally, it woudl be a HDMI to component coverter which I could put just before my TV input. Then I could use standard HDMI output devices that will be available for many (relativly speaking) years in the future.
Posted on Apr 21, 2008
    Scholar:
  • 90 Answers
Get an upconverting DVDP that puts out 1080i on component. They were made several years ago, and today it can't be done without HDMI, which your set is too old for.
Momitsu, Bravo, Lite0n made them, with the Samsung 841 hackable for that purpose. Try to find one used, and be sure to ask whether they upconvert SD - standard - DVDs from 480i->1080i before you buy. Then take that 1080i in via component, which is stellar in its performance and has none of the anomalies that are plaguing HDMI on many brands of CRT units.
Mr Bob
Posted on Feb 04, 2008
How do i get my vizio in full hd
Consult the owner manual to make sure the input it is connected to is 1080 and you are on that input-------HDMI? Component? 1080 Component?
Apr 16, 2012 | Televison & Video
THE HD INPUT WENT TO 4810 RATHER THAN 1080, ANYONE KNOW HOW TO TURN IT BACK
It is determined by a box if used, a setting in the box or set and in some cases the box automatically determines the 480/1080.
I can also be use of the correct input (component versus HDMI)
Often overlooked if a box is to reboot the box itself (unplug power for a few minutes to box) Plug it back and allow it to reboot---this problem is rarely in the set---contact your signal provider if you cannot resolve it.
Apr 01, 2012 | Daenyx Televison & Video
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Cant go from 480 i to 1080 any suggestions?
How do you have your Blu-Ray player hooked up?
First, you have to set your Blu-Ray player to output 1080i (the highest resolution that the Mitsubishi WS-55511 can support). Then you hook up the player via component to the DTV component input on your set (it's the only input that can handle 480i/p and 1080i).
Good luck.
Danny
Dec 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Vizio lcd
This model supports the following formats: 1080i, 720p, 720i, 480p, 480i. Most likely it isn't the TV that is not allowing the 1080i resolution but rather your cabling or the inputs that you are using.
Be sure that that you have an HD signal coming into the TV. You may have to upgrade your cable subscription or if you already have the channels sometimes you have to tell your cable box to use 1080. The same goes for DVD players; they often default to only 480 to maximize compatibility.
The other area to check is your cabling. For the best results use HDMI or Component video.
If you have already checked both of these options let me know & I'll try to come up with some other options for you.
Feb 17, 2008 | Vizio GV42L 42 in. LCD Television
Can i upgrade to hd on this tv
I am not finding anything on the net about being able to upgrade it but the HD in the model # stands for high def but the tv is old enough that it may not go up as high as 1080 most likely just 480i or p which can be achieved with an s-video or might be 720 with the R/B/G connector or a DVI connector, you can look for converting cables on ebay
Jan 26, 2008 | Akai PT4298HD Rear Projection Television
Mitsubishi WS-65809 65" Rear Projection Television Logo
169 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
