Canon PowerShot G6 Digital Camera Logo
Anonymous Posted on Mar 08, 2017
Trying to mend my PowerShot G6
Good morning, yesterday I tried the 'bounce' test with this lovely camera, it failed miserably. The result of the drop is the zoom action has stopped. It looked fine when I first looked at it, turned it on fine, tried the zoom first it worked then it stopped. When I looked at the case the part of the body containing the lever etc was slightly adrift of the main body, stupidly I fiddled with the lever (now stiff) pushed the housing home, heard a snap and messed it up completely. I have opened the casing and can see that when the lever moves it connects with a plastic lug (now lying next to the camera).
Is it possible to buy this section anywhere?
Is there a working diagram anywhere I can use?
Is there any way I can cobble this back together myself?
I should add, I had to take a very deep breath before even taking the case apart, so anything practical has to be fairly easy for me to follow..
Many many thanks, regards, Elaine
Tony Parsons
Level 3:
  • Canon Master 6,405 Answers
  • Posted on Mar 08, 2017
Tony Parsons
Canon Master
Level 3:
Answers
6405
Questions
Helped
1652253
Points
20272
Unfortunately, it will be beyond economic repair, and it is unlikely spares are available to other than authorised repair facilities.
5 Related Answers
Anonymous
  • 298 Answers
  • Posted on Dec 15, 2007
SOURCE: Powershot G6 -- Zoom button stuck
Does it display any of these messages
t00nz
CameraR
  • 4738 Answers
  • Posted on Jun 04, 2008
SOURCE: Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
A
Anonymous
  • Posted on Jun 26, 2008
SOURCE: canon powershot a70 take apart help
Useful link: http://f20c.com/stuff/canon/partslist/
Rolf
Anonymous
  • 30 Answers
  • Posted on Oct 18, 2009
SOURCE: Hi, I dropped my A650 and the case is dented
No, you would have to send the product to Canon for repairs, and it would most likely be cheaper to just buy a new camera. I hope this helps!
Anonymous
  • 11967 Answers
  • Posted on Apr 26, 2010
SOURCE: Canon PowerShot X3 digital camera viewfinder and LCD screen prob
When you disconnected the camera from the computer, did you remember to use the "safely remove hardware" function? If not, you may need to reset the camera. If you can get into the camera menu, just scroll to find "reset" and follow the instructions. If you can't, try this. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
I'm having problems downloading pictures from my Canon PowerShot G6 camera to by computer. Can you help?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dropped SD750 on floor, now won't turn on
That's a hard one to analyze through email. A camera tech would have to use test equipment on it to see if the power section got shorted when the door opened when it hit the floor. It may not be a cheap or easy fix, but only a tech can tell. I have heard of cameras getting damaged, just from putting batteries in backwards, so a short circuit might have damaged a chip inside. Of course a warranty does not cover dropped cameras, but you might want to have them look at it and tell you what it will cost.
1helpful
4answers
Where can I buy a replacement LCD screen for my Canon Powershot G6?
i just purchased an lcd for my a720IS directly from canon. total cost was less than $30 including shipping.
call them at:
US: Canon +1 732 521 7230 / +1 800-828-4040
good luck.
chris c
4helpful
Blank screen
Did you accidentally hit the lower left "Display" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Driver
trying to get a driver download for Canon PowerShot G6
G6 spare part
try ebay http://cgi.ebay.com/Canon-PowerShot-G6-G-6-Repair-Parts-NEW-OEM-LCD-SCREEN_W0QQitemZ260170086348QQcmdZViewItem
3answers
Canon g6
Has the camera been dropped or anything? Did this suddenly happen?
2answers
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
