Question about Xtreme Sound WMS230 Cassette Player
Inline fuse just need to know the amps on the inline fuse for this unit
  • 86 Answers
Hello most amps will run 15/20 amp fuse on the main power supply .if it has a remote turn on this will be around 3 amps..i would not go to big as this is your protection if there is a problem.
Posted on Feb 13, 2008
Do the Sunbeam microwave oven have an inline fuse? I have no power in the unit at all.
Jack,
Most microwaves have a fuse inside the unit. Make sure that you have unplugged the microwave and then remove the cover and look for where the power cord goes into your microwave. Follow the black wire from the power cord and it should take you to either an inline fuse holder or a small circuit board where the fuse will be mounted. You will need to replace it with the same size fuse and the amp rating will be stamped on one of the silver collars. Hope this helps!
Aug 03, 2015 | Sunbeam Microwave Ovens
Went to turn on my heater and got no clicking sound to ignite the fire ? have changed the batterys for new but still not clicking
you will need to let us know what your heater is. car , home, RV, or is it a portable unit?
sounds like whatever it is, your igniter is either not getting power or is burnt out, I would check for an inline fuse 1st. if that is blown, replace it with the same type fuse. for instance, the inline fuse on my home gas furnace is a 10 amp fuse, located in line on a red wire inside the cover of the furnace.
Feb 21, 2015 | Cars & Trucks
Galaxy Pluto - what size fuse do i need for the DC inline fuse holder?
Most of the CB radios I have worked with used a 1 amp inline fuse as a general rule
May 11, 2013 | Galaxy Radios DX-93T Base CB Radio
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
Amp is blowing inline fuse everytime i connect the pos.&neg. wires
Hi thetexster74,
Blowing of fuse indicated of shorted parts inline with the supply voltage. Most common shorted parts is the sound output IC which is mounted in the heatsink. If your handy with electronics, have knowledge in soldering and desoldering technique, pull-out this IC to the board and then try the unit. If the fuse does not blow this time, you must replace this IC and your unit will back to normal again.
Let me know if the symptoms still persist after you've done the above solution.
Hope I helped you.
Thanks for using Fixya.
Jun 02, 2011 | Rockford Fosgate Punch 45 22.5W x 2 Car...
Can i reset my Konica Minolta C250 transfer unit and fusing unit?? Is there a chip reset that I can buy for the transfer unit and fusing unit? I just purchsed the resets for the image units and they worked...
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Sep 30, 2009 | Konica Minolta bizhub C250 All-In-One...
I need to know what inline fuse goes to model number MRV-F307
The fuse should not be any higher then the total fuse rating on your amp/amps.
Sep 06, 2009 | Alpine MRV-F307 Car Audio Amplifier
Changed battery cable now radio will not even come on.
When you said inline fuse I get the idea that this is not the original radio. Do you have power on the inline fuse? The 50 amp fuse you checked is a bit much for a radio. There may be a smaller fuse in another fuse area of what car type you have. If you do not have power at the inline fuse find some where you do have power (12vdc) and connect to it. If you have power at the in line fuse check the ground wire. If you have a test light or someway of checking for power test all fuses everywhere. If you have a fuse location guide for this vehicle look for the fuse for radio. If it was a add on or after market radio they probably caught power from the original source That is fused under the dash.
Jan 13, 2009 | Alpine CDM-9821 CD Player
Inline fuse
There are 3 fuses protect the alternator. 7.5 amp ALT-S, 7.5 amp IGN and 15 amp GAUGE; no "inline fuses".
Jul 02, 2008 | 1993 Toyota Paseo
Will not power
Yeah my guess without seeing it is that you did fry your amp. You really need to hook up two fuses inline on your power feed; one no farther than 18" from you battery and one inline at you amp.
Jun 25, 2008 | Rockford Fosgate Punch 301S Car Audio...
Xtreme Sound WMS230 Cassette Player Logo
66 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
