Question about Canon PowerShot S30 Digital Camera
Download pics The camera came with a "Dazzle" usb connector, however the pins bent. I am using a "non-Dazzle" USB cable, however my pc is not recognizing the camera drive. It notes taht new HW is installed, however does not see it as a drive. Any suggestions?
    Problem Solver:
  • 17 Answers
Install the canon drivers again.
Posted on Feb 15, 2008
6ya staff
SOURCE:
I need a camera cable (USB) for my casio EX-Z9 exilim. How can I find the right one?
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
Nov 05, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Cannon EOS file curruption
Check that all the pins in the USB cable are straight and not bent. You will need a torch and possibly a magnifying glass to see this, also check the camera side to see there is no occlusion of the connectors. Check the PC end of the plug for the same. You dont have to have a a CANON Usb cable just buy one that fits, most Tandy stores or similar can help you there just take your camera with you for the fit
Please rate our help to keep the FREE service online++++Thank you for using FIXYA
Sep 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am trying to find that what type of cable I
depending on what connection you have on your computer. You can use usb to usb or dv to dv. If you use usb to usb it's pretty straightforward but if you go dv to dv just make sure which dv connector you have on your computer 4 or 6 pin. If you don't have a manual for your jvc , go to their website and download one. All of the info will be in there, usually towards the back of the manual. My suggestion would be if you have a dv connector on your pc you should use that setup because it is faster than usb. But if you don't have a dv connector, usb to usb is fine. Have fun.
Jun 29, 2009 | JVC GR-D270US Mini DV Digital Camcorder
Computer does`t recognize psp
try to use another usb connector cable with your psp. It has some lost connection...maybe the data connector is loose. USB has 4 pin(pc side) the voltage supply for power and the data pin..just try.. if it doesnt work...checked if your in admin account because some hardware cant be installed if your not the admin of the pc.
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
Camcorder to laptop connection w/ s-video cable
Cavie54,
Look carefully at your camcorder manual. I'm fairly sure that the the s-video is strictly an output to a TV or VCR recorder. Notice that the S-Video connector is located next to the white and yellow A/V connectors which are also output. Do you have an S-video input on your computer? That would be unusual unless you have added a TV tuner/DVR card. The only way I know of getting this camera's output onto a computer is to use an analog A/V converter which outputs on a USB port. One such box is the Pinnacle Dazzle device (just google it). It's about $40. Unfortunately the most popular Movie program is the Microsoft MoveMaker. Unless it has changed recently, it does not support USB input, only Firewire (IEEE1394). Some software I've used (maybe Roxio, maybe something with the Dazzle) can copy the USB input direct to DVD. Once it's converted you can source MusicMaker with an input DVD and then do your editing and creative stuff
Hope this helps??
John Estal
aka Johnny Wayne
Sep 19, 2008 | JVC GR-SXM37 S-VHS Analog Camcorder
How do I extract video from the tape of the dcr-hc42 ntsc onto my computer, using the USB connector stand? It seems to only let me read the 128MB memory card.
exactley-usb only for downloading photos-need firewire cable and firewire port on computer- says dv on camcorder -always 4 pin on cam could be 4 pin on laptop also or 6 pin on mac and desktops-if no port on comp use pinnacle dazzle-will convert a/v from cam to usb
May 20, 2008 | Cameras
Yes, it is in VCR Mode...
You need a 6 pin to 4 pin firewire cable, friend :) It should work with one of those.
Apr 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Solution
Since you havent got USB (I assume an older or non functional usb port) buy a serial data cable with one end the serial connector and at the other end the mini usb connector to plug in the phone.
I dont know your location but these can be found for app. 20$
You have to use software as well such as Motorola Mobile PhoneTools which is free.
Mar 27, 2008 | Motorola Mobility RAZR V3
JVC Everio GZ-MG37u Cant Connect to Pc
how to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Feb 24, 2008 | JVC Everio GZ-MG37 Camcorder
PC won't recognize Lumix DMC-LZ2
TheThis may be a USB connector fault on the camera[a bent pin say] The easiest and cheapest way is to get a USB card reader and stop using the camera this way. I doubt if it is a repair option if it turns out to be a camera fault.
May 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Canon PowerShot S30 Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
