Question about Canon PowerShot G5 Digital Camera
G5 Powershot Cannon
When I depress the shutter button to take a picture the shutter does not close. I can hold the button for a lengthy time and sometimes a shot will take but will not be clear because of the pressure of waiting for so long for the lens to close. It is extremely frustrating as I like pointing and shooting photos, I cannot wait for the camera.
  • clownfight Feb 26, 2009
    Colleen,
    Thanks for your suggestion. I've got my $11.00 Precision Electronics Cleaner from Radio Shack and have tried to spray it into the top of shutter button around the edge of the chrome part in hopes that it will get down to the contacts, unfortunately it doesn't seemed to have done the trick. I have sprayed the cleaner at the 12, 3, 6 and 9:00 positions allowing it to dry in between spraying it at each position. I have also sprayed it up and under the zoom control and tested it after drying, but got the same results. When you fixed yours did you remove the button some how? I am confident this could be a fix, but I am not sure I am getting the cleaner where it needs to be. If you have any suggestions they would be greatly appreciated.
    Thanks,
    Ron
I posted this on another link to this site where they were having the sam eproblem so this may work for you.
OK, I think I worked it out. The shutter button was not working correctly. They wanted at least $182 to ship it off to a Canon repair facility. Give me a break! My husband spilled coffee on his personal laptop and then several weeks later spilled juice on his work laptop...I'm thinking...hello...learn any lessons yet. Anyway, he couldn't get the keyboard to work properly on his personal laptop (apparently it didn't like all the caffeine) so he bought some Precision Electronics Cleaner at Radio Shack and tried to clean it. That didn't work so we had to order another keyboard. But, that gave us the idea to try the cleaner on the shutter button. The button worked fine in the half way down focus position so we figured the spring under the button was still working but the contact when you pressed it all the way down was not activating the shutter. If we jiggled the button a bit it would take the photo so that meant the contact needed cleaning in order to take a picture with out mashing or jiggling. So short story long, I sprayed some in there and then blew some air into it to dry it out a bit quicker. The spray evaporates anyway, but that just sped up the process. It works like a charm now!!! YEAH!
Let us know if this helps. Good Luck!
Colleen
Posted on Jun 29, 2008
    Problem Solver:
  • 11 Answers
It is possible that you are pressing the shutter button down in one complete motion. The shutter button should be depressed half way, to allow the camera to achieve focus, and then the rest of the way. This also allows the camera to meter, and give you any warnings, such as a camera shake warning if you are in low light without a flash.
Posted on Feb 12, 2008
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
The shutter button doesn't take a picture
you have to hold down your shooter button a little longer for image to be taken.it makes it look as if you are pressing the button twice. the first captures the image and the second takes the actual shot.QED.
Dec 29, 2009 | Canon PowerShot A540 Digital Camera
Sometimes it takes a few seconds before my Canon Powershot SX10 IS will take a picture I have button pushed down but it won't take the picture?
Unfortunately that's how the camera is designed.
The camera has to do a number of things before it will take a picture. It has to check the lighting, and focus and make calculations based on those factors about how to set the camera to take the best picture.
It is best practice to get your subject in view. depress the shutter button half way and hold it so it can focus and determine the exposure, and then completely press the button the rest of the way to release the shutter.
Good luck
Oct 27, 2009 | Canon PowerShot SX10 IS Digital Camera
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Jul 23, 2009 | Canon Cameras
Screen is black on camera Cannon PowerShot SD750
Am assuming that you've already tried pressing the DISP button, and that didn't fix it. Have you tried downloading the photos since this occurred? Are they also black? If so, then you're likely experiencing a stuck shutter.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
Apr 25, 2009 | Canon PowerShot A630 Digital Camera
Cannon powershot g5
powers on but no picture through the viewfinder
Feb 27, 2008 | Canon PowerShot G5 Digital Camera
Shutter Lag-Time
The G5 has a rather short shutter lag and a rather lengthy focus lag. So if you half depress the shutter release to focus, and then moments later fully depress the shutter release I expect you will find very little lag. But I would not expect a prosumer model to focus fast. hope this helps,
Sep 14, 2005 | Canon PowerShot G6 Digital Camera
Canon PowerShot G5 Digital Camera Logo
166 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
