Dualit Vario 2 Slices Toaster Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The center panel of my 2 slice Dualit toaster is not heating. Can I replace it?
espressonist
Level 3:
  • Master 1,711 Answers
  • Posted on Apr 02, 2010
espressonist
Master
Level 3:
Answers
1711
Questions
Helped
651655
Points
5029
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
1helpful
One side of my dualit 4 slot toaster is not working can you help?
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Remember that the six in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Inherited a Dualit Vario 3 Toaster without instructions
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Good Luck
3helpful
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Dualit Toaster won't heat on either side.
You may have awire that has burned off or the control switch is bad. You can get to their site by typing in "dualit" under google and you will get a lot of information and the web site.
Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
DUALIT 2 slice toaster
The Dualit Repair Center is:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
3helpful
2answers
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
2helpful
2answers
Dualit 20247 2-slice crumb tray needed
At the Dualit Service Center:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
1helpful
3answers
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
Top Dualit Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
