Question about GE GSH25JFR Side by Side Refrigerator
Water dispenser : the water freeze
The fridge is not dispending water any more 'cause the water is freezing at 3-4 cm from the exit, inside the tube : when i put hot water in it , it works again for few hours ....is there a "electric heater solenoid" around the tube in the door avoiding this trouble and doesn't work in my fridge any more ?
  • 1 more comment
  • Anonymous Feb 09, 2008
    I have the same problem. The water dispenser will work fine for a day or two, then we'll get a total freeze in the water line. No water. We turn the fridge off for 4-5 hours (or overnight), and let the water thaw. It's fine for a few more days, then repeat the procedure when it freezes up again.
    THIS APPEARS TO BE A KNOWN DESIGN FLAW IN GE REFRIGERATORS. TO DATE, GE HAS FAILED TO FIX IT, THOUGH THERE ARE REPORTS THAT THEY ARE WAIVING SERVICE FEES (BUT NOT PARTS FEES) FOR A REPAIR. I suggest calling GE and complaining. They won't fix it until enough people complain.
    My parents have a 20 year old fridge with a water dispenser that works just fine, so apparently designing one that works properly is well within the current state of the art. For some reason GE hasn't changed their design, though. I leave it up to the reader to decide why.
  • Anonymous Feb 19, 2008
    Open freezer door for a couple of hour or take a hair dryer and blow warn air in the dispensing area on the backside of the door for about 5 minutes. Work for a day or two then
  • trishabennet May 20, 2008
    Same issue, GE was of no help when I called.  Just said I would need to schedule a service call.  AAAARGH, I've already spend $300 getting the water pump replaced, don't want to dump any more money into it.
All,
I hve the same problem of the water not coming out. After reading this forum that suggested this is caused by a frozen line, I increased the temperature (less cold) of the fridge and freezer, and turned on the light (generates heat in the area). After a couple of days, the water worked.
Tom Z
Posted on May 25, 2008
6ya staff
SOURCE:
Water line freezing in door of GSL22JFXJLB Side by Side
the problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
Mar 11, 2015 | GE Refrigerators
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Not dispensing from refrigerator door
that is a possibility .. no knowing exactly what model you are speaking of I would check the water inlet valve.
Oct 21, 2008 | Refrigerators
Whirlpool refridgerator ice maker
Check your water valve. Most likely it is leaking by the seal on the icemaker side of the valve so that it is getting a slight trickle of water all the time to the fill tube. This will freeze in the tube much like an icecicle is formed. This is the most common cause. Low water pressure and mineral deposits inside the tube can cause it also, but it usually will take longer than a few days for the problem to reappear.
The dispenser housing and parts on your fridge are replacable and show to still be available.
You can go to sears.com, click on parts, enter your model number, and see parts diagrams and lists for your fridge.
This link should go directly to the parts site.
http://www3.sears.com/
Post back and let me know about the water valve.
Thanks/Mike
Jan 06, 2008 | Refrigerators
No water at door
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep it from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Jan 01, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Oct 11, 2007 | GE GSH25JFR Side by Side Refrigerator
Water Dispenser freezes
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep if from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Jan 07, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
271 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
