The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
Try connecting the cable to the Coolpix and then turn on the camera before plugging the USB cable into the computer. Another way to transfer photos to the computer. Remove the memory card from the Coolpix and insert the memory card into a USB memory card reader then connect it to the USB port on the computer. The computer will see this as an external storage device, you can then open the folder/s and copy the photos from the memory card to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Is the camera recognised by the pc as a usb 'drive'.?? If not try another cable. If another cable does not help, then the fault could be with the camera itself.
Try inserting the card in a separate card reader attached to a pc - if you can see the latest pics taken, then the camera is taking pics ok - and we are back to the transfer problem.
If you can see the pics in your 'my computer' then you can copy or move them onto your pc's hard drive. The fault then could be your Nikon transfer program. Try reloading the software as it may be corrupted on your pc..
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
see first urs usb cabel is well fitted in urs pc or not or wid camera..... if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader......
but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not.... ask me if it creates more problem.....
My kodak easyshare camera will not transfer my photos to the computer.
Everything is plugged in and the camera is blinking but nothing is
happening. Please help. I checked the connections, they are fine.
