Question about Hotpoint WMA30 Front Load Washer
Wont pump water
Pump starts at the end of wash cycle before spin cycle but wont pump water iv checked for blockage changed pump,one cycle it works next it wont any ideas
  • 552 Answers
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Posted on Feb 04, 2008
My nec nwtl456 washing machine wont empty all water when spin complete anoying is it the pump or?
Can you hear the pump motor running when you first turn the program on, or during the spin cycle? a sort of glug glug noise when the drum is NOT turning. If you can, but the water is not draining, you have a blockage somewhere. If no glug glug then the pump is seized with a coin or pin etc and must be removed and freed or replaced.
Check any filters fitted first; remove and clean them. Lower the grey drain hose onto the floor - does water run out? if not, blockage maye be in sump hose or pump chamber (sock, etc)
If it does run out, blockage will be in connection to sink / waste pipe on your domestic plumbing.
Feb 03, 2018 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
My machine wont spin or turn i took the back off the machine and in the tank there is water in it and wont come out
firstly,the machine will not spin if water is in it.the spin cycle starts when the tub is drained of all water.you seems to have one or a combination of these problems; drainage/blockage/pump motor/no signal/no voltage.does the machine complete the wash cycle?
Nov 20, 2012 | Avanti W789SA Top Load Washer
My washing machine wont wash or spin proprly
the water is not pumping out because you have a blockage in the filter unit which is located at the bottom of your machine or possibly a weak pump. the reason that your machine smells is because the water is not discharging. check the filter first for any blockages, i.e coins, bra wires etc. if that doesn't sort it you may need a new pump
May 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
Water wont empty from machine.not spinning properly.clothes v wet at end of cycle.
Hi pauabreen
On the spin cycles (F or J) does your motor attempt to 'spin' up for about a second then basically fail.
Declan
Nov 01, 2010 | Electrolux EW1000i Front Load Washer
Washing machine doesn't spin..clothes are soaking wet @ end of cycle
this could be due to blockage @pump or the motor wont spin if water not pumped out ..Check filter/clear pump.please leave me me feedback.
Apr 08, 2010 | Kenmore Elite 20972
The water will not drain out
Check on tips for finding if you have a blockage, or pump fault.The door will open if you can remove the water.I have tip posted. for checking this problem
Mar 05, 2010 | Washing Machines
Hotpoint WMA30 Front Load Washer Logo
160 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
