Error E005 Plase Help me ? Where is the function ' S ' Key on Canon GP 335
  • 2 more comments
  • kyawzaymin Feb 05, 2008
    Thanks For Your Answer
    But I cannot find the Function Key.
    Show me with photo.
  • kyawzaymin Feb 06, 2008
    I have already replaced the cleaning web. I opent the front cover and find a small hole to call the "$" sign. But I cannot find .
    If you have other method to call "$" sign , please show me.
    My copier is Canon GP 335.
  • kyawzaymin Feb 10, 2008
    How to call the service mode "$" sign in GP 335
  • Anonymous Jan 31, 2009
    show me the small hole above the fusing knobe on the Canon GP 335 COPIER
  • 1,326 Answers
Are you looking for the service mode. A E005 is the fuser cleaning web counter. Have you replaced the cleaning web? If so, open the front door and look above the fusing knobe for a small hole above it. Insert a sraighted out paper clip in to the hole and you will see a "$" sing show up in the display pannel. Touch the "*" botton the the numbers "2 & 8 " at the same time then the '*' botton the display will change to service mode. Hit the #6 for counters and scroll till you hi-light web next hold the "clear" botton and reinsert the paper clip in the hole from before and the counter should reset to all zeros. Then turn the main power switch off the on and that is it, done
Posted on Feb 05, 2008
  • Chris Coughlin
    Chris Coughlin Feb 06, 2008
    The Funcution key is actually called the "Additional Funcution" it is on the control pannel it looks like * with a circle around it. Also " Funcation" is in service mode you have to clear the Error code
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
Error E005-have replaced cleaning How do I get in
You enter the service mode by pressing the push switch inside the inner front cover by the meter. there's a small hole, insert an allen key or paperclip and press gently. A "$" will appear in the display when the service mode has been activated. Once in the service mode press * then 4 then * to enter the function mode. Use the > key to advance to the second selection press 1 then * to clear the error and power cycle the copier. If the web has been installed correctly and the web sensor is ok. The error should clear after cycling power.
Aug 25, 2011 | Canon NP 6050 Copier
How to resset the E005 error code in cannon GP335
I'm not familiar with the GP-335 but it may be similar to the GP-30 for America. This is an error for the deplecition of the fixing web. That will have to be replaced ( P/N FY1-1046-000 ). The nget into service maod and reset the web counter in COUNTER section.
Jun 17, 2011 | Canon Office Equipment & Supplies
Main power switch off on, E005, canon gp 335
E005 means that the cleaning web needs to be replaced.
May 29, 2010 | Canon imageRUNNER 400S Copier
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
How can i remove a E005 on a have a canon np6330.they is no aditional function key.if posible pliz give me the key code to reset the machine
E005 code means that the Fixing web needs to be replaced. Even if you were able to reset the code, the machine will start jamming with extreme frequency and deteriorate (damage) the Fixing rollers. I recomend having a qualified service tech remedy this error.
Jun 11, 2009 | Canon imageRUNNER C3200 Copier
Remove canon copier problem e005 np6330 on display
You will need to replace the cleaning web that rides above the upper fixing roller. There is a sensor that reads the amount of web left... Good Luck
Error code 005 for canon GP 335 CONTINUES TO APPEAR
press additional function button once and press 2,8 buttons at a time & press additional function button again & execute the following
select <copier> <counter> <misc> <fix web> then press clear button on the display.
automatically the web counter will be zero , the proble also cleared.
Jan 27, 2009 | Canon imageRUNNER 210S Copier
E005 error
push *28* then copier>counter>misc-fix-web set to 0.
Feb 07, 2008 | Office Equipment & Supplies
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
589 people viewed this question
jasbo
jasbo
