Question about Sharp UX 510 Plain Paper Thermal transfer Fax
Question what kind of paper should I use with this fax?
  • 72 Answers
Depends on the quality you are looking for... standard paper would work fine but if you want it to look a little better then i suggest a multi-purpose paper, they are brighter and look nicer :)
Posted on Nov 16, 2008
  • 4 Answers
Any good quality printer paper.
Posted on Feb 04, 2008
Error e030 copier toshiba 202L
E030 indicates Paper remaining inside the equipment at power-ON.
If no paper is found, probably the actuator/sensor is faulty. Kindly perform input test on following sensors:
Exit sensor 03-[FAX]ON/[2]/[B
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Aug 28, 2012 | Toshiba e-Studio 202L Copier
Receiving fax
The error comes, even there is a small bit of paper between the rollers. Kindly check the rollers properly
Sep 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
The fax will not pull the paper through
What kind of fax? Is it a roll or plain paper. Pull the paper out and examine the roller that is pulling the paper in. If this roller has white paper dust on it wipe off with some water on a papertowel and try again.
Apr 13, 2010 | HP 1010 Plain Paper Inkjet Fax
NO....
well try to check and correct if the paper was not properly inserted, and kindly see/check if you got an status message "recieving" on the fax...
thank you,
micro
Jun 30, 2008 | Brother IntelliFAX 4100 Laser Fax
PANASONIC KX-FM386CX DRIVER NEEDED
Kindly help me to down load install this machine
P K Kutty
May 01, 2008 | Office Equipment & Supplies
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax
Check the toner cartridge. Try printing on different kind (weight) of paper. Check HP's site for newer drivers.
Mar 28, 2007 | HP 1040 Plain Paper Inkjet Fax
Sharp UX 510 Plain Paper Thermal transfer Fax Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
