Question about Sharp UX 108 Roll paper Thermal Fax
Light or not printing on left side, sometimes middle
I bought this sharp UX-108 (telephone/fax)about 15 years ago and never had a problem with it. It uses a thermal roll of paper, but I don't know if it takes a cartridge or what I can do to bring it back to the way it used to print. Or is it kaput?
  • foolmoon1 Feb 19, 2008
    Thanks so much. It's pretty much the same conclusion I'd come to.
    President:
  • 2,072 Answers
Anymore it is more expensive to repair a fax machine than it cost to replace it most of the time.
I would say its time to replace it. Parts cost on those are increasing dramatically.
Posted on Feb 14, 2008
  • Rick Kasper Feb 19, 2008
    I did look the ribbons up for you fax, they are $15 at many online locations.
    I wish I had a more acceptable answer for you, but after 15 years, the problem with any piece of office electronic equipment becomes issues with connectors and contacts building resistance, and often times issues become more complex then you expect.
    I noted in my responce that you asked is it Kaput, and that was pretty much where my answer was based.
    Your particular for of fax is more or less based on a dot matrix form of printing.
    I have always thought if you are happy with the equipment you have, don't spend the money on replacing something you really like. The problem you will run into if you have to pay someone to service an older piece of equipment, is, you will have to weigh whether it is worth the investment.
    Restoring your fax is most likely possible. But the real question is how much do you want to invest in an older technology.
    Sorry if my answer was not what you were looking for. But I just base what I offer on 30 years experience, and that opinion is that if you are in business, keep the technology as current as possible and keep as many warranties and maintenance agreements in tact, since I see so many people run into huge bills unexpectedly for equipment.
    It is very frustraiting the price of ofice equipment parts. Basically the manufactures offer the equipment at close to or even below cost to ensure revenue flows with supplies and service maintenance, and even though I never used to believe in maintenance agreements, service costs are a killer now days, and I can't even offer so many services on products as I would like because of the cost prohibitiveness of servicing small office home office products. It is frustraiting
    Your very welcome
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: OUTGOING FAXES FOR SHARP UX 108 THERMAL FAX MACHINE
I need the operation manual
Posted on Jan 20, 2008
When I try to make a copy in My fax sharp ux-108 the paper goes out blank
First make sure the original document is loaded with the correct side facing down. If not the problem try taking out the roll paper and reload it with the other side of the paper facing up
Jan 23, 2012 | Sharp UX 108 Roll paper Thermal Fax
How to change language?????? kindly explain
Click on the link below to view the Sharp UX 108 user manual. Inside this manual it will show you how to change the language:
http://www.scribd.com/doc/31544424/Sharp-UX-108-UX-178-UX-188-User-Guide
Jan 26, 2011 | Sharp UX 108 Roll paper Thermal Fax
Cant receive faxes using sharp ux-108 model
If it sends ok, then it has probably been switched to "manual reception" or "telephone mode" from "automatic reception" -check manual on how to set.
Dec 04, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX 108 manual
http://www.usersmanualguide.com/sharp/faxes/ux-108_178_188
That will have what you are looking for.  Please dont forget to rate!
Mar 06, 2009 | Sharp UX 108 Roll paper Thermal Fax
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX-108
There is probably dust under the glass on the mirror...have to remove the glass to wipe the mirror off with a cotton swab, but removing the glass is tricky and very easy to break. Was the first one printed from the fax? I assume that you can receive faxes just fine, but the streaks appear when you copy or send out faxes...
Would be cheaper to replace the fax than repair it.
Sep 08, 2008 | Sharp UX 108 Roll paper Thermal Fax
Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
I must have an operation manual so Ican follow instruction and at the same time I will know what is the trouble.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
How to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX 108 Roll paper Thermal Fax Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
