Question about Canon PIXMA MP160 All-In-One InkJet Printer
Genuine PG-40 re-fill attempt
Hi guys,
I am trying to re-fill the original genuine cartridge and it doesn't have any holes??
There seems to be 3 possible locations to perhaps drill a small hole. Is this what I should do and which hole should i attack?
By the way, great service. Much appreciated.
Richard
The ink hole is below the label on the top of the cartridge. You have to drill a hole to refill and then use tape to cover it (make sure you put a smal vent hole in the tape with a pin). The key is to disable the ink cartridge monitor for low ink. I am still trying to do that now.
Posted on Feb 12, 2008
    Sniper:
  • 60 Answers
Here a video instruction how to do it:
http://www.inktec.com/english/movie/BKI-9040D_eg.wmv
It suppose you have the refill kit from Inktec, but whatever, take a look.
And rate the solution if it helped you :) !
Thx
Posted on Feb 04, 2008
I have CL 52 and want assumed to MX310. shows the codeu 059. whether it will be possible to submit the cartridge CL 52 in MX 310? How to do it ?
Below is the list of cartridges the MX310 accepts:
Black: 219 pages (PG-37), 329 pages (PG-40), 510 pages (PG-50), Colour: 207 pages (CL-
38), 312 pages (CL-41), 545 pages (CL-51) [2]
Black: 1785 photos (PG-37), 2760 photos (PG-40), 5310 photos
(PG-50), Colour: 85 photos (CL-38), 126 photos (CL-41), 204 photos (CL-51) [3]
No other cartridges fit. srri
May 30, 2011 | Office Equipment & Supplies
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
Ink refill not detected
you must reset the cartridges on mx300
check here the ways
http://inkfilling.net/instructions-on-how-to-refill-canon-pg-37-pg-40-pg-50.html
Jul 25, 2010 | Canon PIXMA MX300 All-in-One Printer
Canon MP210 getting E5 message with PG-50
Sadly Canon cripple many of their printers so that they will not accept the high yield cartridges such as the 50 & 51. As a result your printer the MP210 will only accept the 37 or 38 cartridges which are only half filled, or the 40 and 41 which are fairly full, but don't contain as much as the 50 & 51. All I can suggest is that you could try to sell the 50 on eBay, and send a strongly worded email to Canon.
Aug 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer not recognizing pg-50 cartridge
I had exactly the same problem. I called the Canon helpdesk and apparently the PG-50 is not compatible with the MP210. I then bought a new PG-40 which works fine.
Bit annoying as I have wasted £35 or so on the PG-50. This is also a bit misleading from Canon as the PG-50 fits into the MP210 perfectly, and when you are looking at it on the shelf it looks like a long-life version of the PG-40.
But there doesn't seem to be any way around it that I have found. Just bite the bullet, write it off to experience and buy a new PG-40.
Apr 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Injectable ink....
opppppppps! the black cartridge is separate for that printer. you need to use the PG-40 ink cartridge for the black.
Nov 24, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
