Apple iPod touch Digital Media Player
Problem for Apple iPod touch Digital Media Player
Itouch 16gb, Cannot get an internet connection
By jules sparks on Feb 04, 2008
I get a full strength wifi connection but cannot get onto the internet as it keeps saying "Cannot connect you to server" what do I do???
Clarification Request
Posted by bolanok on Apr 19, 2009
Where do you get the numbers? The IP address and the DNS number on the computer???
Same Problem
May 05, 2009
-   This uhh mo ****** won't connect me to my mo ******* itouch to my mo ******* pc and i'm starting to get pissed off and what not-   oohsoplain
May 03, 2009
-   I touch connects to the internet everywhere else no problem, at home the WiFi is checked, and it says connected - the password has been entered correctly - but safari, facebook etc won't connect to the internet. A real pain! Cannot seem to find a simple answer here. Hope somene can help -   Ceemes
Apr 29, 2009
-   i can't connect my i touch to my wireless internet lynksis.
8gb... this sucks.
I knew my password, but it won't work!!!-   Guest
Apr 28, 2009
-   i dont know how to connect the the i pod touch to the internet -   Guest
Apr 25, 2009
-   I have an ITouch and I can't figure out where you enter WEP Key number. Since I don't use WEP key number one how do I change the WEP Key numbedr?-   adisilve
Best Solution
posted on Jul 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
wow, ive read so many solutions on the internet to try to fix this problem and this is the only one that has worked for me. GREAY JOB!!!
Solution #2
posted on Jul 22, 2008
Helpful)
sne24mary
Rank: Apprentice
Rating: 94%, 17 votes
where do i get the dns number?
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 18, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
alright i need alot of help! with my internet i tryed all of that HLEP ME!
Solution #4
posted on May 03, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i tried that. but it still doesn't work!
Solution #5
posted on May 21, 2008
Helpful)
w2knever
Rank: Apprentice
Rating: 89%, 28 votes
I solved my wifi problem by checking the dns settings. When I 1st logged on to my home secure wifi network my router uploaded all of its dhcp & dns settgs to my itouch. My itouch could see my router; I could ping my itouch's ip address from my
pc..but my itouch would get server could not be found in safari.
After trying multiple times to renew my dhcp lease & resetting my network settings on my itouch-all to no avail-I erased all of the dhcp settings that were uploaded to my itouch, and using the static ip setting I manually entered the ip address,subnet mask,router ip address, & dns address into my itouch(all of these settings I copied from my router settings). THE ONE THING I NOTICED WAS THAT THE DHCP OF MY ROUTER ENTERED -2- DNS ADDRESSES INTO MY ITOUCH.I MANUALLY ENTERED -1-DNS ADDRESS-THE ONE THAT DIDN'T BEGIN WITH 192.168.XXX.XXX . IT WORKED!! Itouch
apparently can't distinguish between 2 dns addresses-it needs one to work with. After doing this I was able to access safari.
Beware of dns addresses that begin with 192.168 as these are just octets that home network routers such as linksys use to designate the wan ip address of your router and as such are not true internet dns server ip addresses. i hope this helps:)
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #6
posted on Jun 06, 2008
Helpful)
kiskit
Rank: Apprentice
Rating: 88%, 14 votes
Just got my 32 gb ipod touch (with updates) today. I also wasnt able to access safari despite itouch recognized my home wireless network. i wrote down all the DHCP settings. I also have an xbox 360. On my 360 I checked the network connections (purple blade for 360 owners). then checked these w/ my laptop's network settings. then i re-typed the settings in static instead of the DHCP section. Actually most the settings were there already. I had to delete2 or the 3 DNS settings (one was the generic 192.168.2.1--erase that) then there were twice listed identical DNS server #'s: xx.xx.xx.xxx (depending on your own server). I erased one of these & was able to get on Safari right away at this point.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #7
posted on Jul 15, 2008
Helpful)
Panchosadie
Rank: Apprentice
Rating: 86%, 5 votes
Ok, I have tried every one of these solutions and I still get "could not open the page because the server stopped responding." Can someone please help me?????
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on Feb 08, 2008
Helpful)
wINdowS_XP
Rank: Guide
Rating: 87%, 56 votes
Try going to the Wi-Fi setting on your ipod touch then tap your home network and when the screen pops up with the I.P Adress, etc...., then go to the button that says " Renew Lease" and Tap it.
It worked for me....hope it helps
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #9
posted on Apr 21, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks! Changing the DNS settings worked!
Solution #10
posted on Mar 09, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try these settings:
* Go to Settings.
* Select Wi-Fi.
* Chose a network.
* Select the blue arrow next to the network you are connected to.
* Select DNS.
* Change the IP Address to 208.67.222.222 208.67.220.220
these worked for me on my itouch 16GB
Solution #11
posted on Feb 15, 2009
Very Helpful)
afto297
Rank: Apprentice
Rating: 97%, 37 votes
Hit "Forget this Network", go to Settings > General > Reset > Reset Network. Worked for me.
Was this helpful?
Yes
No
33 people thought this was helpful
Solution #12
posted on Dec 28, 2008
Helpful)
rebecca41497
Rank: Apprentice
Rating: 92%, 6 votes
The password is your encryption code.
To find out your encryption code.....
1. Go to My Computer (or just computer for WindowsVista)
2. Go to Hard Disk Drive "C"
3. Then click on the file with the name of whatever router company you use (e.g. Linksys, Belkin, Netgear, etc.)
4. Then click on Wireless Settings
5. Then at the top, check to see if that's your network name. (If it is, continue with the directions. If it's not, then go back to the file name of your router and choose the other Wireless Settings file.)
6. If it is, click on it and look at the page and look to see if it tells you the encryption code.
7. On your iTouch, go to settings.
8. Then click general.
9. Then click network.
10. Then click "Wi-Fi".
11. Under where it says "Choose a network...", click your network's name. It will then ask for your password. Look back at your encryption code, and type it in.
You should be all set!
If this doesn't help, try going to the nearest Apple store. They can set you up with a technician. (You have to set up an appointment) They have very nice service.
Trying to talk to your router company, probably won't help. Your router is not the problem.
Well, Happy Holidays everyone!
And I hope this helps!
From,
Rebecca
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #13
posted on Jan 18, 2009
Helpful)
arisu9
Rank: Apprentice
Rating: 88%, 6 votes
i didn't have any bars at first too. i thought that it was going to automatically find my network again after i restored my itouch. but this was what i did to solve it:
1) click settings
2) click Wi-Fi
3) choose other (i tried choosing an existing network that was listed, but it still wouldn't connect, so click other)
4) enter the SSID (which is like the network name, ask your internet provider if you don't know/forgot what it is)
5) select what type of password it uses, i think either WEP or WPA might work, but they both worked for me
6) click Other Network back button to return to the last screen, it will now give you a space to enter your network's password
7) enter your network's password
hopefully that solves it :]
Was this helpful?
Yes
No
Solution #14
posted on Jan 07, 2009
Helpful)
malkeri
Rank: Apprentice
Rating: 83%, 3 votes
i got mine to work by writing static ip's for all my addresses, so my cpu was 192.168.0.1, and so on. i am using a me102 netgear access point. my internet is through my usb. bridged the connections togther. rewrote the ip in the access point to 192.168.0.7. then made sure all adresses are on the same network (this simple check ,i didnt do cost me 2 hours -.-). then wifi conneciton on itouch just do it self and then bingo done.my dchp on iTouch goe slike this
Ip address : 192.168.0.224
subnet mask: 255.255.255.0
router: 192.168.0.1
DNS: 169.254.213.78 ( i dont understand wher this came from, as i it generated from somewhere, i cant figure out where from , checked my external ip that thats not it)
then done any more info send me email at chronos_malkeri@hotmail.co.uk
Was this helpful?
Yes
No
Solution #15
posted on Mar 08, 2009
Somewhat Helpful)
drhladik
Rank: Apprentice
Rating: 75%, 2 votes
I deleted the dns number and entered the one listed above, unfortunetely that didnt work so I deleted it and turned it off and on again and poof it worked! When I checked the dns setting it was the original dns number which is the same as the router number, who knows but its working now!!!
Was this helpful?
Yes
No
Solution #16
posted on Feb 28, 2009
Somewhat Helpful)
united99
Rank: Apprentice
From your network settings change to static from dhcp then manually add in your ip address and, subnet mask and router settings which you should have from router. This solved my problem. The router I was using is a Netgear DG834PN. Good luck
Was this helpful?
Yes
No
Solution #17
posted on Feb 13, 2009
Somewhat Helpful)
j_dragon515
Rank: Apprentice
Rating: 75%, 1 votes
I was having sam prob. with my 16gb Itouch not being able to connect to internet for 2 days. I tried a few things I read here then I just simply unplugged my netgear wireless modem for about 10sec. plugged it back in and it started to work again and it has 2 dns addresses in it. Hope this helps someone.
Comments:
Feb 13, 2009
- Try unplugging the modem for about 10sec. then plug it back in see if that works.
Was this helpful?
Yes
No
Solution #18
posted on Feb 01, 2009
Somewhat Helpful)
musicmp3
Rank: Master
Rating: 81%, 7 votes
I have seen many ipod touches come in to my shop for the same problem, contact the manufacturer or service plan provider to get it replaced, or fixed... What happens is many of the wifi circuits are bad, why, (I do not know) what I do know is the easy fix is to just get it replaced (better than waiting for a fix)
Was this helpful?
Yes
No
Solution #19
posted on Dec 20, 2008
Somewhat Helpful)
illuzn
Rank: Apprentice
I work in tech support and just had a customer call in with this same issue. I had him access his modem and change the WEP key for his wireless to his phone number area code included. logged on with his touch and was surfing in moments. He had been trying all these other solutions for weeks. Give it a try. Hope it helps.
Was this helpful?
Yes
No
Solution #20
posted on Sep 23, 2008
Somewhat Helpful)
Meekaa
Rank: Apprentice
Rating: 75%, 6 votes
Hi
I actually just recently bought a new 16gb I touch. At first I didn't know how to operate the internet but figured it out. From your home page, you would choose settings. On the screen should indicate WIFI button. Click that button. You would first set up your wifi on your itouch to the router coming from your house or an unsecured wireless site. After it is connected, then you would select that router connection Ex. Linksys SES..... then it should go into the WIFI settings. Scroll to the bottom at the HTTP Proxy, select NONE. After I changed the setting, I went to safari and was able to access the internet. I hope this help :)
Was this helpful?
Yes
No
Solution #21
posted on Aug 17, 2008
Somewhat Helpful)
fixerya
Rank: Apprentice
Yea the DNS worked wow. Thanks it took 2 minutes to fix after troubleshooting forever.
Was this helpful?
Yes
No
Solution #22
posted on May 23, 2009
Not Rated)
toadfish316
Rank: Apprentice
Rating: 0%, 0 votes
Simply changing my password on my router (removing characters and changing the password to numbers only) worked for me. (I struggled for hours, setting up static ip addresses etc before i tried this).
I have a Netgear and followed these instructions to change my password "Netgear routers use Web-based administration, so you need to accessyour router's private "page." On my Netgear router, I would go to http://192.168.2.1 -- you can also try http://192.168.1.1 or visit http://www.myipaddress.com and try going to the address listed there.
The username will be "admin" and the password is not your currentsecurity key -- by default is "password" or "1234" for older routersunless you've set it differently. If all else fails, you can reset therouter completely by pressing the indented button on the back of it(you may need a pen or straightened paperclip to reach it).
Once you've logged in, click 'Wireless Settings' on the left and theoption for the security key will appear on the bottom. Remember, onceyou change the password, you will need to correct it on any devicesthat connect to the router or they will be unable to connect."
Hope this helps.
Was this helpful?
Yes
No
Solution #23
posted on May 13, 2009
Not Rated)
aprei
Rank: Master
Rating: 80%, 33 votes
Hi Friends,
Apple iPod touch Digital Media Player's main problems are Touch Screen and Internet problems.
For such problems you can visit a link by just Click Here .
For any other problems with this iPod you can Click Here .
Was this helpful?
Yes
No
Solution #24
posted on Nov 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
lol i cant even join my house network... yes my house netowkr has password and i keyed in the correct pasword and the security is WEP so i did the settings exactly like on my windows Xp but they still keep saying unbale to join network. please help me
Solution #25
posted on Aug 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I tried everything on here but nothing still works
Solution #26
posted on Aug 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All of these are great solutions but unless you have high securiy settings on your router you might have to open ports so that is can connect.
Solution #27
posted on Jul 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
im having thAT PROBLEM TOO
Solution #28
posted on Jun 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Only 1 DNS number is needed for the DNS setting.
Popular Solutions for Apple iPod touch Digital Media
Questions and Unsolved Problems for Apple iPod touch Digital Media
Do you recommend Apple iPod touch Digital Media Player?
Answer
Answer
want to synx music from windows media player to my i pod touch
Answer
Applications that i added open then close immediately. I downloaded applications both from the... (More)
Answer
I try to sync my iPod with Itunes and I get a message that say "the ipod cannot be synced, the... (More)
Answer
My Ipod Thouch will not connect to my Zyxel prestige 2000 series modem....
Answer
I have a ipod touch and it is in perfect condition appart from listening back to downloaded... (More)
156 Other Users Have The Same Problem - Continued
Comment by bolanok, posted on Apr 19, 2009
where do you find the settings on the computer? the ones with the IP adresses and the DNS numbers?
Comment by taennis947, posted on Apr 19, 2009
In the signal bars it is full but when I ever try to connect it says "safari can't open the page because it can't find the server" anyone has any ideas for this
Comment by ny eagle, posted on Apr 17, 2009
I am getting internet access on my laptop but cant download anything on my I touch not sure of the security code
Comment by rissa_rawr, posted on Apr 17, 2009
i know my network password, and when i put it in my ipod touch it just says "unable to join the network" any help please?
Comment by Guest, posted on Apr 16, 2009
i have 8gb on my itouch and i have done everything for my network but it just wont work... is there a number that i can type in and it will all just work?
Comment by midmaine2003, posted on Apr 16, 2009
Same as all these others can get mail etc but have to reboot itouch to reset connection setting just to be able to use safri
Comment by azlanzainal, posted on Apr 08, 2009
My itouch 16gb have a strong signal of the wi fi but cannot get connected to the internet this only happen with my own wi fi at home, oherwise at any unsecured or public wi fi it have no problem connecting to the internet.
If this is because of my router how can it be solved?
Comment by miurashigeji, posted on Apr 04, 2009
cannot connect the enternet and cannot send and recieve messege no signal
Comment by marisatrejo2, posted on Apr 04, 2009
i have an itouch with great wifi connection but when i try to do anything that involves the internet it says can not connect you because there is no internect connected!!! what do i do???
Comment by yojfresh, posted on Apr 03, 2009
My wi-fi in my house is strong, i know the password and i try to join but it keeps saying "unable to join to the network '[my network]'"
Comment by Guest, posted on Mar 30, 2009
it conect to the wifi but i stell dont have intenet
Comment by zombie3, posted on Mar 24, 2009
I have a 16gb itouch and a belkin router . The router has been set to only recognise my dell desk top computer and dell laptop. How can I get the system to recognise the itouch as well so that I may have internet access on the itouch as well as the two dell computers. I only want access to these three pieces of equipment.
Help please
Chris
Comment by Guest, posted on Mar 21, 2009
I think the really deep scratch right by the wake/sleep button might have something to do with it. Also when I turn it on it says "iPod is disabled connet to itunes''.
I went into area with known wi-fi connection. No password, no coffe purchase, only connect. Safari, itunes, and other internet connections would not connect even though I had the bars "saying" I am connected.
Comment by Guest, posted on Mar 19, 2009
I touch 16gb, Cannot get an internet connection
Comment by Guest, posted on Mar 18, 2009
samee vv
Comment by Cjaviery, posted on Mar 16, 2009
can't connect to safari or itunes
Comment by Guest, posted on Mar 16, 2009
it says cant connect to internet
Comment by Guest, posted on Mar 15, 2009
i cant either
Comment by mosty_man90, posted on Mar 12, 2009
i got a 16Gb itouch and every time i get a connection it wont connect me to any site b/c it says that i'm also not connected to itunes but it never gave me an option to log-in to itunes, what do i do?
Comment by Tooshy, posted on Mar 05, 2009
I have the full bars on Wi-Fi and it says its loading when I touch like the App store. Then it says it cannot connect. Please help!
Comment by vrishti_, posted on Mar 01, 2009
i got 32gb itouch
it worked very well with internet till last week
but then youtube stopped working
n now internet i cannot open anything
Comment by Guest, posted on Feb 21, 2009
i have full bars and it wont let me do anything like app store,itunes stoere, or even safari.nothing and i dont know what to do.it let me on two weeks ago and now it just not working.
Comment by Guest, posted on Feb 19, 2009
my internet has the full bars but it says it won't connect.
Comment by Guest, posted on Feb 17, 2009
i have a full bars on the internet but it wont let me on. i even put the password in when it asked me to. help!
Comment by Guest, posted on Feb 16, 2009
my 32gb itouch wont let me join a network
my ipod gets the signal but wont let me browse the internet or anything
Comment by michaelgrind, posted on Feb 10, 2009
I have an 8g itouch. When i try to pick a network its locked. but when i find one that dosnt have a lock it still wont let me get online, even when it has full bars, what do I do?
Comment by Guest, posted on Feb 10, 2009
when i go to the settings for the wifi connection it says that i cannot access to shadow why cant i
Comment by Guest, posted on Feb 02, 2009
my itouch says connection to the server "imap.aol.com" failed
Comment by dm_c5, posted on Feb 01, 2009
same here shows full bars like it is connected use to be but now both mine and my wife's wont connect you'd think spending that much it would last a little longer only been 3 months
Comment by Guest, posted on Jan 31, 2009
NONE OF THESE WORK!!!!!!
Comment by tionnewhite, posted on Jan 31, 2009
i cant connect to the internet or wifi
Comment by alexcontrera, posted on Jan 31, 2009
my i pod touch shows a list on networks and i pick some that are unsecured and it says not able to connect when i have full bars
Comment by jcolon, posted on Jan 25, 2009
My network shows up in the list of Wi-Fi networks, There is a IP address and a subnet number but no router or DNS numbers? When I first tried to set up the network I did enter the WEP number but I can’t seem to connect. I can connect to the internet on a unsecure network that shows up on the list but not mine.. Please help …
Comment by Guest, posted on Jan 24, 2009
My internet is perfectly fine and has no password yet my ipod touch says it is unable to connect. Please help me to get my internet on my ipod!
Mine has the same problem! Nothing I find of the internet helps!
Comment by neek_2110, posted on Jan 23, 2009
i have connection to the internet but it will nt connect to the the wifi connection
Comment by robyn102, posted on Jan 23, 2009
full network coverage but it says the server stopped reponding
Comment by Guest, posted on Jan 23, 2009
says server stopped responding-but I have complete network coverage
Comment by MagicClover, posted on Jan 13, 2009
ok so im having same trouble on my itouch 2gen too....i got my itouch 1 month ago and was getting network fine all of a sudden one day it didn't work. i've typed in all setting and info needed but there is no renew lease button there..i go into default network and check and renew lease buton is clearly there...i've tried turning off and on itouch nothing...anyone help!!??
Comment by Guest, posted on Jan 08, 2009
how do i
set up my ipod touch
heloo every one, My I pod is disabled, and I can not remember the passscod, waht should I do,???
Comment by shari16, posted on Jan 07, 2009
i have an itouch 16gb i can find wifi networks and everything but everytime i try to connect is says that is unable to connect to any of the them.
Comment by Guest, posted on Jan 07, 2009
i am connected to WiFi but when i use the internet on the itouch, it says there is no connection
it says i have all 3 bars on my ipod touch but it wont connect to anything
Comment by Guest, posted on Jan 04, 2009
whenever i try to select a network that is not locked such as linksys it sais unable to join network linksys but whats weird is it sometimes works but some times it doesnt,
Comment by matt98_atm, posted on Jan 03, 2009
Where do I get the DNS number? Please help.
Comment by Guest, posted on Jan 02, 2009
Yeah. My Itouch won't connect to the Internet. Although it still connects to my Lynksis router. My Laptop connects fine though.
Comment by Guest, posted on Dec 31, 2008
ipod touch gen 2 won't connect with my d-link 2310 router even though i have a good signal
Comment by tomrags, posted on Dec 31, 2008
It tells me that I'm using the wrong password to connect to my wireless routher, but I'm not. I've double (and triple) checked the router and the password to get to the router is the same and works. So it's something with the itouch and the interaction of the router. The itouch internet works because I took it to the store and the guy was condescending because it was working in the store.
Any thoughts on how to go about fixing this?
my WIFI on my internet says its not connected..so if i can at least fix this issue then i can do my iTouch and access it.. but dont know how to connect it to my internet.. and i have a 8GB iTouch
Comment by sc_claw, posted on Dec 29, 2008
What if you don't have a wireless router? And I am using a Mac at home too, so I seem doubly stymied. I love my iTouch but would love it more if I could use all its apps.
Comment by hot---chi719, posted on Dec 29, 2008
i dont kno how to get WiFi
Comment by tiptip869, posted on Dec 29, 2008
well i have a itouch 8gb, and i cannot get internet everytime i go to youtube it say internet not connected!!!!!!!!!! so how do i connected internet??????????
Comment by Guest, posted on Dec 29, 2008
i type the right password for the connection for my linskys router but it says it is an incorect password and cant connect
Comment by caskerten, posted on Dec 28, 2008
I have a full wifi connection, and my laptop is working fine on wifi. But my new ipod touch says cannot find server.
Comment by Guest, posted on Dec 28, 2008
It works for unsecure and wep, but cannot get it to work for WPA.
Comment by gra1025, posted on Dec 28, 2008
will not connect when network secured with WPA. Works fine with no encrytion.
Comment by Guest, posted on Dec 27, 2008
i type in the right password but it doesnt connect to the internet
Comment by pinkykotecha, posted on Dec 27, 2008
i hava a16gb ipod touch and i wwant to go to the internet i have a router at home but i tried all of the solution but nothing worked i cant go on to internet plz help me i want internet in my iTouch
plzhelp me
Comment by girlingreen6, posted on Dec 26, 2008
I have my IP address, but what do I put into the Subnet Mask, Router, DNS and Search Domains boxes under Static?
Comment by Guest, posted on Dec 26, 2008
i can find my name and i now my password but its says it wont connect..WHY
says it cant connect when i can see the server name and i know the password...wtf?
i have an itouch and i try to get on the internet but i cant. i got some servers, but they are all locked. what can i do to get the internet?
I get connected to the wi-fi signal but then the internet doesn't work...
Comment by Guest, posted on Dec 25, 2008
my itouch does not recognize my network name?? why
Comment by bigb12997, posted on Dec 25, 2008
i cant get wi fi connection
same with me
Comment by rhiokai, posted on Dec 25, 2008
Same!! it says i'm connected to the internet but can't access it saying the server isn't responding
Comment by katojr20, posted on Dec 23, 2008
when i go into settings it says that i have a wifi connection, however when i try to go onto safari or the app store it says that i can't connect
Comment by Guest, posted on Dec 21, 2008
it wont work
Comment by Guest, posted on Dec 19, 2008
cant hook up to home internet it asked for a password i put it in and nothing happens
Comment by pecker666, posted on Dec 18, 2008
typed in password and keeps and saying cannot connect to the service
Comment by this stinks, posted on Dec 18, 2008
i dont know how to get a WIFI network onto my itouch
Comment by Guest, posted on Dec 14, 2008
My Itouch wont connect to the internet, even tho it has wifi connetion that is strong, and i cant do anything on it cept listen to music pu contacts i and make notes.  Help plz?
Comment by macy95, posted on Dec 13, 2008
my internet onmy itouch is not working all it says is cannot connect to server.
Comment by Guest, posted on Dec 11, 2008
I can not connect to my home wireless connection
Comment by Guest, posted on Dec 07, 2008
i have the same problem its really annoying me
same here
Comment by Guest, posted on Dec 06, 2008
same as everyone else cannot connect to server
My itouch cannot go to youtube. It keeps saying that I have to connect to itunes first, but I already did.
i need help cuz i try to go onto the internet on my itouch and everytime it tells me to enter a password and i dont have a password!!!! what do i do?!?
Comment by barkiwi, posted on Dec 06, 2008
Cannot get internet connection even after trying setup from main computer, this is bogus as it is one of the reasons I bought the itouch 8gb.
Comment by metzler24, posted on Nov 22, 2008
Idk how to connect to the internet with through wifi. I know that linksys is involved but idk if u need a wep code or w/e. idk even how to find that
Comment by John B 816, posted on Nov 12, 2008
Please describe the specifics of your problem below. We'll add
your post as a comment to jules sparks's itouch 16gb, Cannot get an internet connection problem, and notify you when a new solution is offered.
Comment by Guest, posted on Nov 09, 2008
I cant get internet on my i-touch i typed in the password and it still doesnt work HELP !!!!
I typed in the password on my i-touch but i cant get internet still!! please help
Comment by vanputten, posted on Nov 09, 2008
Comment by buckwheet, posted on Oct 15, 2008
for my 16g itouch it wont let me go into my wi-fi settings at all ever since i got it, and when i go into safari it says, safari cant open the page because its not connected to the internet, what do i do
Comment by Guest, posted on Oct 15, 2008
It says Unable to connect to network when it is listed right there in my networks.
Comment by mldygles, posted on Sep 03, 2008
I have the same problem with my itouch 32G, I have had it since Feb, 08 and have not been able to access any wifi or any of my other options offered on the home page, ie.. Safari, itunes store, etc... I would really appreciate it if some intellegent soul could kindly email me and walk me through it. I love this thing and would love to check my email and email customers. That is why I purchased this. I even downloaded this upgrade recently. My teenage daughter told me to she thought that it might help with the connection problems.??? Can someone please help?
Comment by valentine10, posted on Sep 02, 2008
My internet access is fine, but whenever i try to connect my itouch, it says "cannot connect to server".
Comment by gurln2kaos, posted on Sep 01, 2008
despite the fact that it finds wi fi connections, all i ever get when trying to connect to the internet is a message saying it can't connect to the server or something like that, what do I do???
Comment by Guest, posted on Sep 01, 2008
i get the connection but still saying " cant find the server"
Comment by Guest, posted on Aug 31, 2008
wifi isnt working and i dont know what to do.
Comment by Guest, posted on Aug 29, 2008
I just got a touch on tuesday and the wi-fi worked fine but since about 4:30 today it has stopped. I tried reseting it and when i try to go to youtube it says cannot connnect to youtube. when i try to access my e-mail it says cannot get amil the connection to the server "imap.apple.mail.yahoo.com" failed????? HELP I HAVE FULL STRENGTH WI-FI
Comment by beverlyo1, posted on Aug 27, 2008
Wifi works fine at home. However at work I can connect to 'free public wifi' Have full bar strength but still says not connected to internet. Have tried resetting but that doesnt work either. Any answers????
Comment by kennethng, posted on Aug 21, 2008
I have a 8gb itouch but that should not be the issue. However, what is the problem is that I cannot connection to the internet even though I have a full bar of strength on my connection. It used to work, but for the past couple days it has not. This is specifically for just one connection but it is the one i use at home. So I was wondering if anybody had any suggestions for fixing my problem.
Comment by Loumartag, posted on Aug 17, 2008
I have a ipod touch and when I go into Safari I get a connection but mail says I cannot connect because I lost the conneciton to smtp.aol.com. I have gone into settings and tried all sorts of suggestions but nothing works
Comment by renzo_90, posted on Aug 16, 2008
when i try to open a webpage in safari...a window in my screen opens and says Safari cant open the page because it cant find the sever. im in my house and i have wireless.
Comment by cutie_pablo, posted on Aug 14, 2008
i have a perfect connection on my itouch but i still cant get on the internet. why?
Comment by zined0527, posted on Aug 13, 2008
I used to be able to connect just fine...now even when im connected (full bars) internet says it can't find the server.
Comment by Guest, posted on Aug 12, 2008
i cannot get internet access on my new itouch.
Comment by heinekein07, posted on Aug 05, 2008
cant get onto internet but havefull wifi signal keeps saying 'cannot connect to internet' or 'server not responding' WHAT SHOULD I DO??????
Comment by Guest, posted on Aug 05, 2008
I cannot get the mail icon on my itouch. I would like to set up safari as well
Comment by Pocahontis, posted on Jul 23, 2008
i don't know what's a wi-fi connection and my ipod won't connect to the internet it keeps saying can't find server what do i do?!
Comment by lorr747, posted on Jul 17, 2008
I am trying to get on a local college open network and Safari tells me "can't open the page because it could not connect to the server." But when I am at home on my closed network it works fine. When I looked at the settings I have a IP Address, I have a Subnet Mask, I have a Router #, but I do not have a DSN #... HTTP Proxy is on Auto. IP Address is on DHCP. If anyone can help please do so.
Comment by Guest, posted on Jul 15, 2008
my ipod touch will connect to the wireless network
i have type the password and have had no luck i have Sky broadband
I am in the UK but the Touch was bought in the US does that make a difference?
Comment by Guest, posted on Jul 11, 2008
I get full wifi connection yet the ipod cannot find the server
Comment by Guest, posted on Jun 28, 2008
every time i type something in the address bar it comes up internet cannot display this page
my itouch will not connect to safari. It can not find the host.
Comment by Guest, posted on Jun 22, 2008
Comment by wernsta2000, posted on Jun 20, 2008
stock in a loop looking for network eventhough my laptop works fine via wifi windows xp pro ipod touch 16g
Comment by Guest, posted on Jun 20, 2008
i cant get a network connection , it just stuck in a loop looking for the network but my laptop works fine
Comment by gotdat, posted on Jun 19, 2008
Comment by Guest, posted on Jun 15, 2008
my internet
Comment by Nick8, posted on Jun 13, 2008
i have full wiif signal but when i go onto safari it comes up with a message saying "safari can't open the page because it can't find server"
Comment by Auzzy7, posted on Jun 11, 2008
My Porblem is i have the full wireless connection at home and it shows on my itouch but it says "cannot find a sever". What should i do?
Comment by Guest, posted on Jun 10, 2008
I downloaded some MicroSoft updates on my new laptop. I have a strong wi-fi connection but I can not get on the internet now. Before I downloaded the updates everything worked flawlessly? I try to uninstall the updates by doing the restore to an earlier date and that obviously did not work.
Comment by Nora0716, posted on Jun 10, 2008
I have the same prob i cant access the internet even with full signal
Comment by Guest, posted on Jun 09, 2008
I cant connect to the internet using my itouch it keeps saying cannot find server what do i do i have a full internet connection and its not finding the server
Comment by weemum, posted on Jun 08, 2008
I have exactly the same problem - can't acees internet or utube.
Comment by Guest, posted on Jun 08, 2008
i try to connect my itouch throught wireless yet it says "unable to join the network" when i connect it... i tried both WEP WPA2 and unsecured NOTHING IS HAPPENING ...PLZZ HELP
I cannot send or receive emails and get the "cannot connect to server, try again later" message. Has happened since I downloaded a free trial of AVG anti virus 8.00 (already had the free 7.5 version). Coincidental, or a connection here?? I have checked my modum connection - no problem. I now intend to access my emails via webmail, but would like the problem solved ASAP. Pamela
Comment by Guest, posted on Jun 02, 2008
cant get on internet says cant connect to server
Comment by katken, posted on Jun 01, 2008
Same Problem I can connect to the server, But when i try to go on the internet it says it can't connect to the server, byt in settings it says its connected, how did this happen?
Comment by gavstar, posted on May 27, 2008
Wi-Fi network is selected and password entered. There is a tick beside network name that presumably means its connected. But, when trying to get onto Safari we get - can't open because it can't find the network Gav
Comment by Meone1, posted on May 26, 2008
i have the same exact problem with my iTouch i tried what it says down here to renew the lease and all that. But when i try to connect to my network is weird because when i type in my password it says Unable to join it. And I tried writting a random name and it worked. And I can't find my DSN that's the only thing I haven't tried. How can I find it?
Comment by Guest, posted on May 21, 2008
if it comes up you need a password like at the school what do i do
Comment by lovcava, posted on May 11, 2008
I have full wifi signal and still says cannot connect to server
Comment by Guest, posted on May 09, 2008
I dont no the password to connect for the internet? How do i find it?
Comment by MissSwiss, posted on May 01, 2008
I am in the same boat, tried to renew the lease, change the DNS, still, no connections despite excellent reception. Help.
Comment by melrosebr, posted on Apr 30, 2008
My ipod makes a connection and keeps the connection, but when i try to access the web or utube it says it cannot find the server...i try changingthe DSN or whatever but that hasnt worked..helppppp
Comment by Guest, posted on Apr 30, 2008
my internet doesn't work at all!!! all it says is can't connect to the server!!!
Comment by jackee010, posted on Apr 25, 2008
it won't connect to the internet and it won't go to you tube either this is some bull
Comment by 4half, posted on Apr 24, 2008
Whenever I try to enter my WiFi password it says that it cannot connect me to the server.
Comment by Raffa, posted on Apr 20, 2008
I cannot connect my itouh to wifi. I have a strong signal. I have tried to renew the lease and the other solution regarding changing the DNS but neither works.
Comment by Guest, posted on Apr 11, 2008
i have the same problem... only diff is im using an 8gb itouch, but i highly doubt that makes a difference.
anyways, i got two other comps on the network, and my router is a linksys
wrt54g
Comment by thoma2, posted on Apr 09, 2008
Same problem.
Comment by Guest, posted on Apr 09, 2008
Same problem
Comment by negors, posted on Mar 23, 2008
strong connection but no internet or you tube can't get help no where even at the apple store
Comment by smiley770, posted on Mar 21, 2008
same
Comment by mela_z, posted on Mar 12, 2008
it shows up that its connected but when i want to get somewere it says "cannot connect to..." and i have a quiet strong connection, please help.
Comment by Guest, posted on Feb 27, 2008
my itouch gets connections but it don't let me get to the internet
Comment by siiiiiii, posted on Feb 24, 2008
Every time i try to get on my enternet or youtube and stuff like that it says,''CANNOT FIND SERVER''.How do I get it to work?
Comment by Guest, posted on Feb 22, 2008
Comment by jajl, posted on Feb 18, 2008
Comment by Guest, posted on Feb 10, 2008
will not connect to the internet wi-fi signal is stroung
Comment by Natahem, posted on Feb 06, 2008
My Itouch would actually connect everywhere else. But when I try at at home, it doesnt connect. I can see the full signal and can see my router too. But it doesnt connect. I have tried at my brother's and sister's places, it works fine. It even works at Starbucks. I dont know why it would not work at my home!! Can anyone help me??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
