Question about Olympus MJU 400 Digital Camera
Got a problem with the lense
I am having problem wit my camera. When i open the lid to take a photo the camera lense doesnt come out what can i do?
  • 1 more comment
  • Anonymous Feb 16, 2008
    I am having problem wit my camera. When i open the lid to take a photo the camera lens doesn't come out what can i do? It just won`t switch on.
  • joji23 May 22, 2008
    Me too!!! my camera model is olympus 410. The lens won't come out & there's only orange lamp flashing.Pls. help me wat can i do?
  • dosjac Sep 26, 2008
    My camera didn't fall at all. I bought my camera feb. 2004. Since then three times the same problem. Two times within guarantee. Now I have to pay 149 euro. Olympus, I'm not pleased.
  • 38 Answers
I had the same problem with mine after it had been dropped on the ground.  I undid the two screws at the bottom which holds the sliding lens cover on and took the cover off.  Check the small black lever inside.  It might be broken.  I replaced the part from an older model and but the cover back on.  I works fine now.  I hope this helps
Posted on Jul 19, 2008
Take pictures, reads unable to recognize files, and doesnt even show i have taken a picture
The camera may require manually opening the shoot lense to achieve flash to capture pictures. Observe the camera buttons for every complementary buttons that may require activation prior to photo shoots. Usually smaller cameras with lenses may require manual lense adjustments prior to every photo shoot.
Feb 03, 2011 | GE X5 Digital Camera
My lense wont open after a fall i want to replace the entire lense module when can i get it
1.) GO to the place where you purchased your Fuji FinePix. They will probably sell you a new lense (or camera). I dought that they wont.
2) if that doesnt work, then you can go to a repair shop and get it fixed.
#) Thank you, and have a nice day
Oct 13, 2009 | Fuji FinePix F20 Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Jammed lens
When you turn it off, does the lense go up and down. If yes good news. while turning the camera off press on the lense very softly (up and down motion) until the lense retracts 100% or almost 100%. you may have to try a few times. if almost 100% retracted, push the lense a little harder in, untill it retracts all the way in. Turn it back on, it should work now. If you do not keep your lense clean you get that problem. After you droped it, some mechanical part on the lense may have broken or dislocated. In this case you have to open the lense inspect the parts, clean them and puth them back together.
Jun 08, 2009 | Polaroid i830 Digital Camera
D50 - image problem
It's the CCD sensor. I had to have mine repaired...unfortunately I still seem to be having the same problem when shooting with high ISO. Guess they didn't completely fix it.
Dec 30, 2007 | Nikon D50 Digital Camera
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Olympus MJU 400 Digital Camera Logo
115 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
