Stuck in Progressive Scan Mode...please help!
I have a Toshiba DVD/VHS player combo and I hit a button today thatmessed everything up. I can watch tv and VHS tapes, but when I try towatch a DVD it turns into a blue screen that says "Progressive ScanMode". I can hear the DVD playing..just no picture. Can you tell mewhat I need to do in order to have the DVD come up on my tv screen?....lost the manual obviously. :(
Model is SE-R0135
Thank you
  • 2 more comments
  • Cindy B Feb 05, 2008
    Thanks drpellypo, but there is no switch on the DVD player..this sucks. Any more suggestions? Any idea where I can get an owner's manual for this model?
    Ok got it. Found the number for Toshiba FINALLY! Anyways so anyone else with this problem, heres what to do:
    Take anything out of player, hold in stop button on DVD player for 5 seconds.........that is all! :)
  • kinkers Jul 18, 2008
    play dvd can here music playing but have blue screen
  • Anonymous Mar 02, 2009
    THANK YOU SOOO MUCH! My TV was also showing the blue screen with the same message "Progressive Scan Mode." I searched on the net for solutions and found your advice. Held the 'stop' button the the DVD palayer x 5 secs and it's all fixed!
    Problem Solver:
  • 17 Answers
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Posted on Feb 04, 2008
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
No picture while watching DVD but sound works
make sure the dvd player is not in progressive scan mode
Apr 13, 2010 | Toshiba 14DLV75 14 in. TV/DVD Combo
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
Dec 09, 2007 | Zenith ZHX-313 System
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
349 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
