Question about Gateway FPD2275W LCD Monitor
Monitor my monitor turned black suddenly,there seems to be a shade of rainbow in the middle of the screen. can you help me pls. Thanks
  • dorotea del Rosario
    dorotea del Rosario Feb 04, 2008
    Thank you very much for your time second2dlast, i have the same problem on the next day, so overheating might not be just the cause and there are no magnetic devices near my monitor. do you have any more suggestions?
    Scholar:
  • 61 Answers
Turn it off for a while, it might be overheated already.
degauz your monitor that can be seen on the menu when you press its button found right at the exterior of the monitor. could there be magnetic devices near your monitor like huge speakers? place them away from the monitor.
Posted on Feb 04, 2008
  • second2dlast
    second2dlast Aug 11, 2009
    sorry that it was just now that I''ve read ur comments. That is a symptom of the liquid on your monitor slowly disintegrating already. LCD monitors unlike the tubed once are actually disposable and cannot be mended anymore once it got such problems.
Shaded box screen
try creating another user and logging in to that user to see if the problem still exists. if you want more help, say what version of OS X you have, and which laptop.
Sep 17, 2013 | Apple Computers & Internet
White screen display
Appreciate the direct "Ask Me".
Often, problems such as this is indicative of a failing capacitor in the 5V internal regulator section. Most capacitors uses a wet dielectric that dries out after some time due to heat buildup. In some instances, most of the capacitors would also fail ESR test. Additionally, you may want to check the external power supply if it is putting out the correct voltage as indicated in the reverse of the adapter box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Computers & Internet
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Gateway FPD2275W LCD Monitor Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
