Question about HP PSC 2355 All-In-One InkJet Printer
Wrong cartridge stuck in printer!
I have put a new ink cartridge in my hp 2355 printer and cannot get it out... any ideas on how to remove?
I had to use two screwdrivers and some elbow grease to get the cartridge out.  Look on top of the cartridge housing for a rectangular-shaped tab.  (Pulling up on the tab with a screwdriver, you should notice some give in the cartridge.)  While using one screwdriver to pull up the plastic tab on top of the cartridge housing, use the screwdriver to pull the cartridge out by wedging the head of the second screwdriver as close to the back of the cartridge as possible, then pushing and pulling simultaneously.  Took a few tries and some wiggly of the cartridge, but it finally popped out.  Beats buying a new printer (or trading up, as suggested by HP technical support).
Posted on Jun 24, 2008
Hi, try to disconnect the printer from the power supply (ie. removing the cables on the back of the printer) and manually move the carriage to the cartridge loading position. If it's locked and impossible to move to the correct position, try to move the paper feed rollers in the contrary motion of the normal paper feeding motion to unlock the cleaning station and try to move the carriage again.
Posted on Feb 04, 2008
I have just had my cartridges refilled and now have reinserted them in printer but it keeps saying remove and check colour cartridge (which i have done lots and lots of times), help please
Ink cartridge contains Ink tank, electrical circuit & print nozzles.
Adding ink to ink tank is called refilling, if any fault in circuit/nozzles will indicates the cartridge error.. Before refilling check cartridge health condition.
In your case its sure that cartridge faulty, go for new one..
Nov 10, 2012 | HP PSC 2355 All-In-One InkJet Printer
Can I use an HP75 tri-color printer cartridge in my HP PSC 2355 All in one printer even though it usually takes the HP95?
HP 75 tricolor cartridge is not designed for PSC 2355.If you try to install it,you'll get a message incompatible ink cartridge or cartridge problem.using a different cartridge may also damage the chip embedded in the printer.do not use hp 75 as a replacement for hp 95.
Jun 19, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hi Experts! I got the message "Remove and check colour cartidge". This is a HP 2355 all-in-one. Can you help me please? Maybe I should clean the cartridge, but I do not know how to do that.
You must be using HP94 95
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP 2355 is not a new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | HP PSC 2355 All-In-One InkJet Printer
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
What ink cartridge does the hp 2355 all in one inkjet printer use
The PSC 2355 uses a standard Black 94 and a Tri-color 95 cartridge.
It also can use a Tricolor-97 and a Photo 99 cartridge.
Here is the HP price list:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=Q5789A&aoid=5504&lang=en&cc=us
Also, here is a link to the main support page for the printer where you can obtain much more info.
HP PSC 2355 Support
Thanks for using Fixya.
Feb 16, 2011 | HP PSC 2355 All-In-One InkJet Printer
Cannot remove Ink Cartridges from HP PSC 2355 all in one printer . Think the wrong cartridges were installed. Installed cartridges are #57 and #58, which I cannot remove.
I actually did the same thing, on a different printer though. If you managed to get it in, it WILL come out. There is no secret answer to this.
You need to be a little more forceful with it. Try to remember how you maneuvered it the first time and work from there. Don't give up ! I work in construction so I have a pretty good grip. You may need to find someone who also has good strong hands.
I hope you get it,
RSMITH972278
Oct 17, 2009 | HP PSC 2355 All-In-One InkJet Printer
Hp psc 2355 all in one. Put new driver hp deskjet
The problem seemed to escalte around the time I installed Internet Explorer 8 . The first thing I tried was to return to an earlier Restore point . When I would click on the internet explorer icon , the screen would flash but I couldnot access the main page . I then moved my restore point to the day I installed Internet explorer 8 . I had several printer errors displayed on the printer . Other than hp I tried to get intouch with Microsoft . Weekday hours for microsoft and not sure what was up with HP on line assistance . Ellimanated all printers and re installed deskjet 990c . Followed windows xp for Dummies for installation . Funny thing ,I can't find that page again .
I fill my own ink cartridges as I live on an island . The printer screen flashed on it;s screen that I had the wrong ink cartridge installed . Just happened to have a new one from Xmas . Installed it and it seems to work . I could also copy from the printer but not from the PC.
The PC works , but the printer does seem to remain connected . I push the start button and find sometimes it comes on . If not I remove and re insert the power cord . It turns on . I then have to go through the proccedure of going to printers and selecting either HP 2355 which is in ready mode, Deskjet 990c (1) in waiting now with a check mark and Deskjet 990 c . I then click to get 990c as the main printer . How the other 2 got reestablished is beyond me ?
I have been thinking of getting a Mac ., but I have been told it would be a whole new learning curve . Iknow they are not also without faults .
As of this reply I believe it is sorted out .Thank you for your interest . I hope this may help someone else ,if it makes any sense .This printer model is no longer made .I
Roger
Jun 21, 2009 | HP PSC 2355 All-In-One InkJet Printer
HOW TO REMOVE THE INK CARTRIGE FROM HP PRINTER 7660
Press the cartridge down when its in the slot and then remove it gently
Nov 25, 2008 | HP PhotoSmart 7660 InkJet Printer
Always used hp tri-color print cartridge in in my hp psc 2355 all-in-one printer. Has stopped working. Says printer has wrong tri-color cartridge inserted
Check manual for appropriate cartridge class for tri color and use same numbers as in manual you may be using 22 cartridge for 28 for example for your printer this cartridges look the same in all aspects but some HP printers can only be used by only one of this types. Check printer manual for compatible ink cartridges. And if you have been refiling the old cartridge you need to get a new one to reset the computer cartridge memory count.
May 30, 2008 | HP Office Equipment & Supplies
HP PSC 2355 All-In-One InkJet Printer Logo
239 people viewed this question
Ben Johnson
