Question about NetGear DG834G Router
Cannot connect to internet
When i try to connect i get-
u have manually set data en crypt mode to wpa-psk tkip.but wireless network is configured to use unknown.connect data encryption settings then try again.
can u tell me how to do this as i am new to computing.
thanks Tom.
    Brigadier General:
  • 6,966 Answers
At most that I can gather from your post/description is that somehow the security setting has been enabled in your router. This would prevent access to the Internet by any PC tied to your network that do not use the said encryption (security) key.
Perhaps the best or the simplest would be to do a hard/full reset of your router. This way all will revert to default factory settings and the WEP, WPA, MAC security will be disabled. There usually is a recessed small reset button at the rear or bottom of most routers for this purpose.
Should this be not corrective, pls post back with information on modem brand/model and what PC(s) (desktops or laptops) and your ISP.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
Nov 24, 2011 | NetGear Computers & Internet
Want to switch from wpa2 to wpa
to configure the netgear router. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Sep 18, 2011 | NetGear WGR614 Wireless Router
Muddytrying to go to netflix, from my WII says my internet connection is not working, but my laptop in on and working.
Greetings,
Did you recently change your encryption or password on your wireless network? It may not work if you are not using one of the following encryption types:
  • WEP
  • WPA - PSK (TKIP)
  • WPA - PSK (AES)
  • WPA2 - PSK (AES)
Try re-entering your wireless settings on the Wii to match the settings on your laptop.
Apr 17, 2011 | Nintendo Video Game Consoles & Games
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
We do not have a secure connection to our wireless rotor
You could change and configure your router through its web interface. To access it, use http://192.168.1.1 on Internet Explorer, and enter 'admin' for the password.
  • Go to Wireless LAN Security tab.
  • Select WPA-PSK on Network Authentication.
  • Enter a password that you want for your wireless network on WPA Pre-Shared Key (minimum characters is 8).
  • Set Data Encryption to TKIP.
  • Apply settings.
You should now reconnect your wireless computers to your network and enter the WPA Pre-Shared Key.
Oct 12, 2009 | Airlink 802.11G Wireless 4-Port Router...
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
Security connectivity issues
is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Jul 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
P-334wt
Suggestion,
First, go to ur Router Configuration Page. There are 2 pg into related WireLess Configuration Settings. So u find ur problem into the WPA security configuration is under the wlan Security section, and then you select WPA PSK (Pre Shared Key) and TKIP encryption for Lan security. As well as changing the WPA Mode to enabled, u will need to enter a WPA Pre-Shared Key. So u found, which is a Network key and why to need.
mr-winthaw@myanmar.com.mm
Raider.CsStriker@gmail.com
Oct 22, 2007 | Zyxel P-334WT (P334WT) Firewall
NetGear DG834G Router Logo
46 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
