Question about Xerox DocuColor 12 Printer
Composition of toners used in DocuColor12 laserjet printer
    President:
  • 2,072 Answers
All of the MSDS are on www.Xeorx.com .
Just go there and search MSDS or PSTD and it is there.
There is nothing harmful in that ink.
Posted on Feb 04, 2008
  • 3 more comments
  • Rick Kasper Feb 19, 2008
    XEROX Material Safety Data Sheet MSDS No:
    B-0311
    Date:
    2/16/99
    Revision:
    2/24/06
    Manufacturer:
    Xerox Corporation Telephone # (s): Safety Information: (800) 828-6571
    Rochester, NY 14644 Health Emergency: (585) 422-2177
    Transportation Emergency (Chemtrec):
    (800) 424-9300
    Section I - Product Identification
    Trade Names/Synonyms:
    DocuColor 12/Document Centre ColorSeries 50 Part No.: WH: 5R616, 5R629, 5R711
    DocuColor 2045/DocuColor 2060/DocuColor 5252 XE: 5R90246
    Digital Color Press/DocuColor 5000 Digital Press/
    DocuColor 7000 Digital Press / DocuColor 8000
    Digital Press/ DocuColor 6060 Black Developer
    Chemical Name:
    None
    WHMIS Status:
    This is not a WHMIS controlled product.
    Ingredients (% by wt.) CAS No.
    Carrier (>93%)
    Manganese/magnesium/strontium ferrite 65997-18-4
    Toner (<7%)
    Bisphenol A polyester resin (90 – 95%) 122970-65-4
    Ca rbon black (3 – 6%) 1333-86-4
    Section I
    Primary Route of Entry: Symptoms of Overexposure:
    Inhalation Minimal respiratory tract irritation may occur as with
    Eyes:
    exposure to large amounts of any non-toxic dust.
    Flush with water.
    Skin: Medical Conditions Generally Aggravated by Exposure:
    Wash with soap and water. None when used as described by product literature.
    Inhalation:
    Remove from exposure. Additional Information:
    Ingestion:
    None
    Dilute stomach contents with several glasses of water.
    Section III - Toxicology and Health Information
    This material has been evaluated by Xerox Corporation. The following toxicity data is based on toner only.
    Oral LD50:
    >5 g/kg (rats) TLV: 10 mg/m3 (total dust)
    Dermal LD50:
    >5 g/kg (rabbits) PEL: 15 mg/m3 (total dust)
    Inhalation LC50:
    >5 mg/l (rats, 4 hr exposure) 5 mg/m3 (respirable dust)
    >20 mg/l (calculated 1 hr exposure) STEL: N.E.
    Eye Irritation:
    Not an irritant. Ceiling: N.E.
    Skin Sensitization:
    Not a sensitizer. XEL1: 2.5 mg/m3 (total dust)
    Skin Irritation:
    Not an irritant. 0.4 mg/m3 (respirable dust)
    Human Patch:
    Non-irritating, non-sensitizing.
    Mutagenicity:
    Ames negative
    Carcinogens:
    None present
    Aquatic LC50:
    N.E.
    The results obtained from a Xerox sponsored Chronic Toner Inhalation Study, demonstrated no lung change in rats for the lowest
    (1mg/m3) exposure level (i.e. the level most relevant to potential human exposure). A very slight degree of fibrosis was noted in 25% of
    the animals at the middle (4mg/m3) exposure level, while a slight degree of fibrosis was noted in all the animals at the highest (16mg/m3)
    exposure level. These findings are attributed to “lung overloading”, a generic response to excessive amounts of any dust retained in
    the lungs for a prolonged period. This study was conducted using a special test toner to comply with EPA testing protocol. The test
    toner was ten times more respirable than commercia
    XEROX Trade Name:
    DocuColor 12/Document Centre ColorSeries 50, DocuColor 2045/ MSDS No.: B-0311
    DocuColor 2060/ DocuColor 5252 Digital Color Press/
    DocuColor 5000 Digital Press/ DocuColor 7000 Digital Press /
    DocuColor 8000 Digital Press/ DocuColor 6060 Black Developer
    Section IV - Physical Data
    Appearance/Odor:
    Black granular / faint odor Softening Range: N.D.
    Boiling Point:
    N.A. Melting Point: N.D.
    Solubility in Water:
    Negligible Specific Gravity (H2O=1): N.D.
    Evaporation Rate:
    N.A. Vapor Pressure (mm Hg): N.A.
    Vapor Density (Air=1):
    N.A. pH: N.A.
    Volatile:
    N.A. % (Wt.) N.A. % (Vol.)
    Section V - Fire and Explosion Data
    Flash Point (Method Used):
    N.A.
    Flammable Limits:
    LEL: N.A. UEL: N.A.
    NFPA 704:
    Health - 0, Fire - 1, Reactivity - 0
    Extinguishing Media:
    Water, foam, dry chemical.
    Special Fire Fighting Procedures:
    Avoid inhalation of smoke. Wear protective clothing and self-contained breathing apparatus.
    Fire and Explosion Hazards:
    None
    Section VI -Reactivity Data
    Stability:
    Stable
    Stability:
    Stable
    Hazardous Polymerization:
    Will Not Occur
    Hazardous Decomposition Products:
    Products of combustion may be toxic. Avoid breathing smoke.
    Incompatibility (Materials to Avoid):
    None
    Section VII - Special Protection Information
    Respiratory Protection:
    None required when used as intended in Xerox equipment.
    Eye Protection:
    Protective Gloves:
    Other:
    For use other than normal customer - operating procedures (such as in bulk toner
    processing facilities), goggles and respirators may be required. For more information,
    contact Xerox.
    Section VIII - Special Precautions
    Handling and Storage:
    None
    Conditions to Avoid:
    Avoid prolonged inhalation of excessive dust.
    Section IX- Spill, Leak, and Disposal Procedures
    For Spills or Leakage:
    If spilled, sweep up or vacuum.
    Waste Disposal Method:
    This material is not a hazardous waste according to Federal Regulation 40 CFR 261 when disposed.
    State and Local waste disposal requirements may however, be more restrictive. Consult with the
    appropriate State and Local authorities for specific information.
    Section X - Transportation Information
    DOT Proper Shipping Name:
    N.A. (Not Regulated) ID Number: N.A.
    Hazard Classification:
    N.A. Packing Group: N.A.
    602E40220
    For toner composition there is no other information humanily possible to find.
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
I have a universal color inkjet refill kit need to know to apply to my laserjet 4000 toner cartridge C4127X
Short answer: you cannot use any INKJET refill kit for a Laser Printer!
Laser Printers use TONER (e.g. powder) and not INK.
Hope it helps!
Sep 18, 2011 | HP LaserJet 4000n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
Yellow Toner leak inside printer
I generally use small soft-bristle brushes to move the toner to locations where I can easily get to it with a small hand-held vacuum unit and just **** it right out.
Apr 07, 2009 | HP Color Laserjet 3550 Printer
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
HP laserjet 1018. "toner can't be found"-an error msg from PC
hi,,
try to use a different kind of toner to fixed your problem.
rey
Nov 10, 2008 | HP LaserJet 1020 Printer
HP Laserjet 4100N saying toner is low when it isn't
yes Is there a sensor in the printer and in the toner cartridge that tells the printer when the toner is low. if u r using new cartridge it indicates perfectly.if u r using refilled cartridge the indication is not always perfect.so u do one thing use your cartridge till u think the printout is perfect do not worry about this messages this is common in many printers.if this solution helps u pls rate it as "fixya" thank u for using fixya.good luck.
Jun 11, 2008 | HP LaserJet 4100n Printer
if you wanna to keep your printer in good health plz don;t tray to use any refile toners
Mar 30, 2008 | HP Color LaserJet 2600n Printer
Xerox DocuColor 12 Printer Logo
771 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
