Question about IBM ThinkPad R50e Notebook
Replacing the oroginal memory
I want to replace my original memory card which I was told was under the keyboard. How do I remove the keyboard and how do I replace the card?
And what kind of card do I need to buy?
  • 1 more comment
  • prussak Feb 05, 2008
    Hi
    Thanks for the quick response.
    My model is Thinkpad R50e.
    It's my first time taking apart my computer - can you please specify how exactly do I remove the keyboard?
    Thank you
  • prussak Feb 08, 2008
    Hi Zim_256
    Thank you so much for the excelent explenation - it was very clear and helped me very much.
  • prussak Feb 27, 2008
    Hi
    Thanks for the helpull links.
    Do you know what kind of memory do I need to buy for my R50e Thinkpad?
    I noticed that the 266mhz cards are much more expensive than the 533mhz and 667mhz cards. Can my computer use the 533Mhz or 667mhz cards?
    Thank you
Hi, if your PC is a IBM ThinkPad, you can lift the keyboard by unlocking both latches on the side of the computer (The same latches you use to open the screen) and then lifting the board in the same way as the LCD screen.
To access the memory you probably has to remove a sticker, some screws or even the Hard Disk Drive.
Tell us what model of notebook you have.
Posted on Feb 04, 2008
  • Anonymous Feb 07, 2008
    Hi again, you can add a DIMM memory without having to remove the keyboard. Your PC has a memory slot in the back, to install it you have to loosen (not remove) a screw that is marked with a small chip. Then remove the little cover of the memory slot and install a compatible DIMM memory.
    OR, if you still want to replace the installed memory you have to:
    First: Remove the battery pack.
    Then remove the three screws marked with a little keyboard in the back of the PC. If you PC has a 14.1 inch LCD, you have to remove a fourth screw to remove the keyboard.
    When all screws are removed, put the computer in the normal position (as if you are using it) and slide the keyboard by pushing the frame of upper buttons (the power/suspend) in the direction of the display, that will unlock it.
    The lower part will pop up, lift up the keyboard holding from the sides.
    Disconnect the keyboard cable and you'll gain access to the RAM memory.
    If the explanation is unclear (And I'm sure it is because i don't speak english very well), enter to www.ibm.com and search "Manual Thinkpad R50e", that will lead to a long result page, search and download the "HMM" or Hardware Maintenance Manual, it has a better explanation with graphics.
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
May 10, 2012 | HP Computers & Internet
May 10, 2012 | HEWLETT-PACKARD Pavilion dv7-4270us...
Satalite m35x-s161 how to replace the keyboard?
Toshiba Satellite How to remove keyboard and upgrade memory modules. This post was written by cj2600 on April 28, 2006
Posted Under: Toshiba Satellite A20/A25 --> toshiba-satellite-a20-a25-memory.jpgRemoving and replacing memory on a Toshiba Satellite A20 or A25 notebook is not as easy ad it should be. Both memory modules are located under the keyboard. A laptop keyboard has to be replaced in order to get access to the memory modules. Before you remove the keyboard do not forget to remove the laptop battery or you can damage the laptop. Be careful when you remove the keyboard securing strip; do not bend it too much. To remove the memory module from the slot on the system board, release the latches on both sides and the memory module will pop up. It will stay at a 30 degree angle to the system board. Firmly grasp the memory module and remove it from the slot.
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
Oct 31, 2009 | Toshiba Satellite M35X-S161 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Space bar missing on hp dv9000 laptop
hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Memory card touble
First, you have to make sure that you have enough memory space on your memory card.
I'm regretfully informing you that this is the symptom once the memory card is starting to quit working. It's eating up the good available memory until you notice that you don't have enough memory space.
The only thing that I could suggest is to reformat the memory card before saving new songs. Or better to create a back up.
Have a great day!
May 17, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
IBM ThinkPad R50e Notebook Logo
189 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
