Question about Dishwashers
Dishlex global 300
Greetings... When I plug in and turn on the power, a beep sounds and stays on....the unit will not work...cant select any wash cycles.....the last time something like this happened the serviceman fiddled with the door latch and hey presto.... fixed....please help
Thanks
Marty
  • Craig Taylor Feb 21, 2008
    I have a Dishlex Global 300, I turn on the pwer at the wall the machine turns on and beeps and then immediately turns off and none of the buttons do anything. If you turn it off at the wall and back on again it rerpeats the same scenario.
  • Anonymous Feb 24, 2008
    I have exactly the same type of problem, my sister purchased hers about the same time and they are having a similar problem. Have had 2 service ment 3 times. First one no help, said it was the child lock. I do not use and and have never. Got another repair man who came twice, said it works don't use Eco. After presseng start about 5 times it would work. Today it won't work again. Have you had a solution to your problem. Have paid out $400. to not have it working when I go to use it
    Problem Solver:
  • 6 Answers
Try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Posted on Aug 09, 2008
Worked a treat thanks, after replacing the sump microswitch which was causing the constant pumping out of water and resting the machine it works like a dream.
Posted on Jan 22, 2009
I have a dishlex global 310 and the power would not come on. It beeped when I turned the switch on and off but would not display any lights. I took the handle off which was sticking and it had a broken part that connected to the shaft on the dishwasher. After fixing it, it started straight away.
Posted on Feb 26, 2013
    New Friend:
Water is appearing a day or two after a wash. Hose has been replaced
Posted on Apr 26, 2010
Same here,
Power ON and nothing
touch a button lights came on and then went out.
Only it was the child lock.
Turn Off Dishwasher
Turn on
hold start/pause and Program at same time till machine beeps
Done
Posted on Mar 30, 2008
6ya staff
SOURCE:
Why won't top load washer turn on?
have a washer mechanic check out the program board and the power cord for a missing earth pin
when using water around power equipment it is normal to have a earth wire for operator safety
Jul 27, 2015 | Washing Machines
My Kenmore Elite Oasis HE washing machine is having problems. We can't find the owners manual but remember that there was something in it regarding reseting the machine. It is starting the cycle like...
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
First the f4 light flashed and we turned it off and on again and put hot water down the pipe which seemed to clear it - then the water finally drained from the maching - then it kept repeating the last 15...
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD to START.
If the issue persists then the F11 error is a Serial Communication Error Between MCU and CCU - Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any wash cycle. Check MCU by looking for operation of the drive motor and check drive motor for powered rotations. Also check the motor and wire harness. Replace defective part as required.
Oct 12, 2009 | Washing Machines
My washer won't turn on. It just beeps when i
Hi, this is a main control panel issue. here is a procedure you can preform to gain control back.
Re-select cycle and press START.
If the problem persist, you will have to have the control panel repaired by the service tech.
Mar 07, 2009 | Whirlpool WFW9400S
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
My washing machine, after washing, changed to the spin cycle then started beeping so I turned it off, re-started it & when it got to the last spin cycle it just beeped then stopped. Now it wont start. It's...
No power? Let's see if we can solve this problem.
  1. Unplug then plug back again.
  2. Start the program.
  • If beeping send for repair/replacement.
  • If not beeping be happy to continue using your washing machine.
Jan 21, 2008 | Washing Machines
Dishwashers Logo
2,888 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
