Question about HP DeskJet 1220c InkJet Printer
Hp 1220c A3 printer not working
When pressing the on button to turn on the printer it quickly flashes green and quickly goes out and stays out never actually staying on making the printer usable.
  • second2dlast
    second2dlast May 11, 2010
    how long do you press the device to turn it on?
    is in properly plugged to its power source? is it in a proper voltage type?
    try uninstalling the printer, then restart your computer.
    install the hardware once more, then see what happens.
    if this continues, there must be something wrong with its power mechanism.
    another thing, how long have you been using this printer? since when did this problem occur? as one reason may be is that one forgets or actually developed a habit of not turning the printer off before cutting its power source because as a power source initially flows into any device that was not previously turned off, the power acts like a jet stream forcing its way through the device. I learned this lesson too when I often forgot turning my scanner off before, before cutting the power source. This is the same to appliances, don't you agree?
    so if the suggested options won't workout, please bring it to a service center for your first hand solutions.
    all the best!
Make sure the back covre is securely locked. Printer will not function unless this is completely secured.
Posted on Apr 09, 2008
Had the same problem, some where there is a fix on the web, changing out a 1/2 watt resistor fixes it!
Posted on Feb 06, 2008
Printer won't turn on.
Common problem with this particular Printer is a Bad Power Supply,needs to be replaced,its nothing related to the cleaning you did.
you have Order a new power supply Board,open the back cover of printer and Install it.
Feb 04, 2012 | HP DeskJet 1220c InkJet Printer
I have an a hp 1220c, When I plug it in and press the power button, the green light comes on for a second and then it turns off. the printer will not start up.
try removing the power cable then keep the power button pressed while the power button is pressed plug the cable back and don't release the button for 5 seconds
then try
Oct 17, 2010 | HP DeskJet 1220c InkJet Printer
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the...
IT COULD BE THAT THE INK SERVICE STATION CANNOT MOVE BECAUSE OF WATE INK.ALSO ADD SOME SEWING MACHINE OIL TO THE SILVER SLIDE BAR THAT THE CARIAGE RUNS ON.DONT GET OIL ON ANY OTHER PARTS
Jun 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
1280 a3 is not printing
Delete the printer and install the printer again with drivers for 1220c. This solution actually worked when i faced the same scenario.
Jun 09, 2009 | HP DeskJet 1280 InkJet Printer
I got printer hp desk jet 1280 i could not print A3 size paper
Delete the printer and install it again using HP deskjet 1220C drivers. This actually worked for me when i faced the same scenario.
Jun 06, 2009 | HP DeskJet 1280 InkJet Printer
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Mar 07, 2009 | HP DeskJet 1280 InkJet Printer
Printing on an HP 1220c Printer scanned photographs
Go to Start
Control Panel
Right click on Printers (on the left hand side of the screen)
Click on Run as Administrator
Click on Server Properties
Click on Continue
Click on Create a new form
Put in the sizes you want (which for you is A3 measurements)
You can do this to create whatever size page you want to print up to A3. All the best .. Tina
Oct 29, 2008 | HP DeskJet 1220c InkJet Printer
Not working
This maybe down to a faulty cartridge replace cartridges and then retry. You can try the following to obtain a test sheet.
  • Turn on printer
  • Hold power button down (While printer is on)
  • Press the paper feed button once
  • Release both buttons
This will printout a test sheet but I really do think that it is a faulty cartridge problem.
Hope I could help
Thanks J
Dec 08, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
202 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
