Have hp officejet 6300 which prints well, but everything is shifted about an inch to the right, meaning there is no right hand margin, and a large left hand one.
  • pascie Feb 04, 2008
    thank you Pauldonp
    I will try your reinstall solution when I get home. I have tried the resets on the printer itself to no avail. The print preview looks perfect, the result is off center to the right.
  • pascie Feb 11, 2008
    Thanks Pauldonp. Unfortunately I tried your solution and it did not work. Even with reinstalled software I continue to have the shifting problem. But I should add that the printer has an alignment problem, as it can't print an alignment page when I reinstall a cartridge. Restoring factory defaults don't seem to work. Any other ideas?
  • 4,102 Answers
Hi the problem is goint to be with the software not the printer if the print quality is fine and its just the page allignment thats out then you will need to reinstall the software that came with the printer this will reset everything back to factory settings and this should then solve your problem.
Also have you looked at the print preview to see if it is ligned up properly on the page let me know ok then i can assist you further ok
Posted on Feb 04, 2008
  • paul proctor Feb 04, 2008
    The best thing to do is unplug the printer from computer then remove the software that came with it then reinstall this should restore to factory settings when you reinstall the software if you need further assistance after doing this let me know but im going to be out for a few hours so will be back online later just let me know ok
  • paul proctor Feb 11, 2008
    Hi ok then if you re done all software install and still have problem then the problem is going to be with the printer software itself this isnt something you can do yourself as the people who work on them plug something into the printer circuit board and this allows them to reinstall the software that is on the printer itself.
    You might even find the board has a problem maybe a part on the board itself has failed the problem is their are no servicable parts on the board itself.
    As you have reset the printwer to factory settings this would have solved any problem with any settings that are wrong on the computer and also any problems with the printer it now looks like something has failed on the printers circuit board but i know they dont repair these as you cant get the parts and also the repairs would cost more than the printer would to buy.
    You could ask a computer shop if you like but im 100% sure they will tell you the same.
    You could try this one last thing
    1. remove printer software form comp
    2. leave printer connected to comp and switched on
    3. goto control panel
    4. goto add hardware devices
    5. let your comp search for devices
    6. scroll down list untill you see printer then select it
    7. dont check the box that says "have disk" leave it blank
    8. let comp search the net for software
    9. when located install
    this might find some newer version of software that might cover the problem you having as new software comes out they improve on it if their is any common problems give this a try you got nothing else to lose but failing this i think this could be the end of your printer that is unless the problem is with the cable itself.
    remove cable and check for damage like kinks or splits in outer casing then put it back and try printing let me know if searching for new software work you might be luck let me know ok
How does new paper go in
fold the paper about half inch down and feed in along fold
Mar 14, 2016 | Casio HR-100TM Two-Color Printing...
Everything is working just fine except the margin on the right and left side is missing some of the printing, like its printing something to wide????
Hello and Welcome to FixYa!
Sir, If there is a problem of margin in printing and except it everything is working fine then this not seems to be the problem of printer, its the issue of the file format, You have to check the settings of the programs which you are using for files printing like if you are using Microsoft Word and you have to print the document of Microsoft Word the check the Margin Settings of Microsoft Word,By Decreasing the width of the file you can bring it in correct format and then printer will not miss the left and right margin.
I hope this solution helps you and you have clear picture in your mind now
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 21, 2012 | HP OfficeJet 7310 All-In-One InkJet...
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
May 09, 2011 | HP PSC 2410 All-In-One InkJet Printer
HP Deskjet 5650 is printing off-center. The printing field is shifted to the right, so the right margin is non-existent and I lose a bit of the printing. How can I fix it?
I think the horizontal printing starting point can be adjusted by holding down buttons (??) when powering up. Right now my left margin is 3/8 inch too big -- photos have that much white space on left margin with borderless printing. I am trying to figure out the key combination.
Jul 27, 2010 | HP DeskJet 5650 InkJet Printer
My E-mail when printing on my HP Officejet J5780 cuts the right 1/4 page off at the right margin: appears that the font and picture sizes are enlarged and is cut of at the right hand margin.
that is not unusual, as emails are non formatted for printers, you may find that making the page 'scale' to the paper in print setup panel, will help this.
Nov 24, 2009 | HP Officejet J5780 All-In-One InkJet...
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP-1120C print out shift
adjust margine of the printer properties as 0
Mar 04, 2008 | Office Equipment & Supplies
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
