Question about Dremel 1800-01 Scroll Station 18" Variable Speed
Dremel Scroll Station 1800
Everything works well, but once in 15 times when I start the saw (variable speed control button is set to low) it goes running on full speed, without soft start, with high vibrations, breaking blades. How can I fix this problem? Is the malfunction electronically generated or am I doing something wrong?
  • lupy Mar 07, 2008
    You should use the saw gently, and the bizzrkness of the tool will be gone. The dremel saw has only 110 W.
I replaced the switch, but the problem is still there
Posted on May 23, 2008
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
    Champion:
  • 313 Answers
The possible problem is the linkage between two arms at the back. remove the 2 special screw & see if they are worm. have to replaced 2 screws & the links. its a common problem for vibration.
Posted on Jun 08, 2008
Dremel 1800 scroll saw manual
Here is a list of what you can get. If it is not listed there then there is a spot at the bottom of the page to request a manual.
Dremel manuals
Aug 22, 2012 | Dremel 1800-01 Scroll Station 18" Variable...
Motor turns a fraction of a turn and stops. I've
With an ohmmeter between the prongs of the power plug and the switch turned on, rotate the motor and watch for a drastic change in the resistance. Theresistance should be fairky low.
IF during the rotation the resistance goes way up, there is a failure of an armature winding.
I notice it says variable speed, so the above may not work. The next plan is to bypass the speed control to see if the problem might be with the control... I suspect that is where the problem is. Bypass the control putting full voltage on the motor an see if it runs. If it does, then speed control has a problem.
Jan 27, 2010 | Dremel 1800-01 Scroll Station 18" Variable...
Hello, I'm missing the nut that holds the lamp on the end of the flexible arm. Is this part available at a Home Depot? Thank you
I bet if one were this part, one could find oneself at a home depot. An individual looking for you would surely be assisted by the home depot staff. Bring the bold with you if you can.
Dec 31, 2009 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel Scrollstation 1800 motor fault
There seems be problems with the electrical systems of the Dremel 1800 scroll stations (had same problem)
Speedcontroller burns out and DC motor gets hit by Main AC voltage.
Earth leakige due to low resistance between DC motor Rotor and earth (flowing current to earth)
Measure rotor copper connections to earth to check for low resistance, should be very high.
Biggest problem is that the main metal body under full main voltage comes and this is a dangerous situation!!!!!!!
All to fix is to repalce (both) fauly parts,
Motor Controller and DC motor
Hope this helps
May 19, 2009 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Breaking blades
You have to use 127 mm pin end blades, and if you apply a side pressure they will keep breaking
May 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel 1800-01 Scroll Station 18" Variable Speed Logo
1,647 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
