Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Problem with 17" ViewSonic Monitor
I have a 17" ViewSonic Monitor. When we trun off the monitor for few minutes after using for 1 or more hour then it does not turn on for the first time. I need to press the power button a couple of times then the green light comes up.
Any help appreciated.
Thanks,
Neeraj.
  • Anonymous Feb 06, 2008
    The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
    But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
    You can now start your CPU.
    Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
    But if there is Viewmeter on screen , this normal and OK>
Posted on Feb 06, 2008
ViewSonic VX1935wm Monitor says out of range
The problem is in the power supply inverter board, usually caused by bad capacitors, suggest a professional.
Mar 10, 2012 | ViewSonic VX1935wm LCD Monitor
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Monitor is changing colors and won't wake up
This problem should not be only with your monitor, but also with your video card. You might have left one image sitting for long hours. There is no specific solution, but for Lcd users, you can try this. Leave the monitor off for few hours without any connection, maybe power chord or vga/dvi/hdmi cable. If this doesn't fix then the problem must be from your video card. You can try the monitor on another system to make sure, which one is the culprit. Your last choice is to reset the bios, to do this, remove the bios battery and leave it for few minutes outside (2 mins will do) and put it back. Reboot your system, this will fix your problem. Good luck. Thanks for using FixYa.
May 31, 2010 | ViewSonic VA721 17" LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
Brightness pop-up window on screen
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
153 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
