Question about Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W30-control buttons stuck
I have had my camera for over a year and it has been working perfectly. I tried to turn it on yesterday and the clock set screen appears but the control buttons are all frozen. Only the power button is working.
Any advise would be much appreciated ;0)
  • 1 more comment
  • claireh Mar 05, 2008
    I have tried turning it off and pressing all buttons but this hasn't helped.
    Any advice would be much appreciated :0)
    I have now tried leaving the battery out all afternoon-but still no joy. It is stuck on the clock set screen (the clock cannot be set) and no other screen can be viewed.
  • claireh Mar 06, 2008
    Thanks for the suggestions.
    I have to admit defeat-my camera is broken!
    Brigadier General:
  • 3,614 Answers
Take a soft reset of your camera, uninstall for the moment the battery and live for a while whithout a power running on it.
Let me know.
Posted on Mar 05, 2008
  • 4,102 Answers
Are you able to enter any menus like setup
  • paul proctor Mar 05, 2008
    Try removing battery then switch back on it could be that your camera has been left somewhere damp and coroded the pads on the buttons causing a constant circuit as if the button is stuck let me know if you have tried removing battery ok
    Hi it does sound like a stuck button or its got wet or damp causing short and not allowing to press any buttons the only thing you can do witch is risky is take the case of and clean behind the buttons i have done this on a different camera and also on phones but they are all different and couldnt tell you how to take the cases off your so i wouldnt do it unless you have some idea whats involved.
    Do you have any warranty left as this is the only way to get it repaired or replaced as you cant get these repaired its just not financially worth it no camera shop will even look at repairing them.
One button of the camera is stuck, try pressing hard all buttons various times with the camera turned off and try using it again.
6ya staff
SOURCE:
I have a sony cyber-shot dsc-w30 and the setting dial is loose just a tap and it switches functions... Can i fix this?
Setting dial has internal carbon coating that seems worn out so it can not be fixed by cleaning etc.
Replace setting dial as it calls Control Switch Block and part number is as follows:
147958411... CONTROL SW BLOCK (SW110T) (W30)
Available with Part Store for $25 and handy person can replace it easily by taking apart camera carefully.
Thanks.
Jul 25, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
When turning on power lcd says acess ,lens opens and closes . then lcd says turn off power and on again.also little orange light indicater at eye viewer flashes.sony cyber-shot dsc-w30.
I had the same problem. Your focus is stuck.
Try to free the focus from whatever (sand, dust, etc.) by hitting the camera. Start gentle, and if it doesn't work, hit it hard...the DSC-W30 is very rugged , that was my experience!
Greetings from Germany and good luck!
Jun 06, 2009 | Sony Cameras
Sony Cyber-shot DSC-W30 Digital Camera dsc w30 digital camera reset
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
Dec 01, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Jun 30, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony DSC-W30
Goto www.digitalcamrepair.com and goto the self diagnosis page to get more info.
Apr 28, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Mode dial lock doesn't work
Always give camera model, wilmyg, so one can offer you a more specific response. Thanks.
Apr 06, 2008 | Cameras
Pre-shooting with sony dsc H2
There's a chance that the settings might have been changed.....Just try after resetting the camera to default factory settings.
Mar 05, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Feb 03, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber Shot DSC-W30 changins picture sizes back to 4X6
Nothing to do with the camera. Its a printer set up thing
Jun 28, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
347 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
john cordey
john cordey
Are you a Sony Camera Expert? Answer questions, earn points and help others
