Question about GPS
Navman S80 will not let me go passed the safety agreement
When starting up the Navman S80 it keeps bringing me back to accepting the safety agreement and will not go further. Is there anyway I can re-set it?
Please help?!!!
  • 8 more comments
  • Anonymous Mar 04, 2008
    I have the same problem, the navman wouldn't even turn on, so i plugged into power and now it won't let me past the safety agreement either, i agree and it goes to the startup screen, some numbers appear across the top for a few seconds then disappear, and it switches back to safety agreement screen again. I've redownloaded all the software from the disk provided and it hasn't fixed the problem. Please help.?
  • violeta399 Mar 12, 2008
    I was able to fix my Navman S80 by reloading the software.
    Maybe try doing it again.
  • write2yatin Aug 17, 2008
    Guys I have the same problem, my Nav man does not go pass the start up screen.
    Can anybody suggest some troubleshooting steps
  • Anonymous Aug 27, 2008
    Same problem. Went back to smith and they wanted me to deal with Navman directly. Trying to get in tounch with Navman...hopefully they will answer the phone before next olympics :(
    S80 is useless
  • Anonymous Aug 31, 2008
    I have the same problem - my navman will not go past the saftey agreement page. Once I hit agree it goes back to the start
  • Anonymous Dec 03, 2008
    Navman S80 will not let me go passed the safety agreement problem, and notify you when a new solution is offered.
  • hamid-k Jan 08, 2009
    where does the product key be? .. i cant find it anywhere in my box ..
  • mlotho Jan 27, 2009
    When I turn my navman on it won't let me go past the safety agreement. What do I do?
  • kathy_mun Mar 05, 2009
    It wont let me passed the safety agreement.
  • Tammalena Mar 08, 2009
    Navman S80 will not let me go past agreement screen.
    Problem Solver:
  • 14 Answers
When I turn my unit on all I can see is the accept/decline screen. The unit will not load the maps. How can I fix this?
Step 1
Connect your Navman Device to your computer via a USB cable.
Turn on your device and you will see a connection screen appear.
Step 2
Wait a few Seconds until a window appears on your desktop and then select “open folder to view” by double clicking on it
Step 3
Once you have opened this folder you will need to double click on “My Documents”
Step 4
Once my documents is opened locate and files that starts with “LOG00” and also “My Mileage” and delete them
Step 5
Once the above steps are done you may disconnected your unit from the computer.
Turn your unit on and enter your main menu page 2/2 and select “Preferences” then select “Route Options”
Once this is selected go to page 4/4 and un-tick “Enable GPS data logging” and “Enable trip recording”
Your unit is ready to use and will run a lot smoother due to increasing unwanted data and freeing space to increase optimum performance. We suggest that you follow these steps once a month to ensure optimal performance.
These steps will work on the S50, S80 or S90i. If you are experiencing this issue on an S30 or any other device, please contact Navman Technical Support on 1300 628 626.
I used this personally on my S80 after it died during my work as a Security Patrol officer and I was not happy, its all fixed now and I have my Nokia N95 loaded with the same places just in case.
Posted on Jul 26, 2009
    New Friend:
Ive dont what you all have said and it still is doin the same **** wont load the map up what else can i do?????
Posted on Mar 14, 2010
  • Anonymous Mar 14, 2010
    hey after doin everything you guys have said it still wont go past the safty agreement i have a s90i can anyone help or do i throw it in the bin???
Had the same problem, I called tech support and all I had to do was connect the Navman to my computer, open my documents on the device and delete all the files saved there for 'logs and milage'. These files had filled up the memory so it could not load the maps. It worked straight way and all my saved loations were still there. I hope this helps. Cheers
Posted on Oct 20, 2008
I fixed it by removing the maps and resinstalling the map upgrade that I purchased a year ago.
It worked for me.
Posted on Aug 18, 2012
    New Friend:
All a bit late I know but having just had identical problem I left device on charge linked to USB port and after and hour everything was back to normal
Posted on Feb 09, 2011
I had this problem after installing the service pack. After no help from NAVMAN I found this
http://www.gps-data-team.com/pda-gps-navigation/topic/2256.html
I followed the advice by Grantdale1 (making sure I did not delete DEVICE.XML) and it worked
let me know if it helps
Posted on Apr 22, 2009
I just installed the service pack and if fixed this problem (that only occurred as I went to get the service pack...)
Posted on Apr 16, 2008
After returning the Navman to **** Smith for a full refund (not successful) they advised me that it will have to be delt with by NAVMAN themselves, it was taken to the 1 and only repair centre for navman products located in Sydney, has been there for a week now and i don't expect to see it for the easter long weekend. Thanks Navman..... ;-(
Posted on Mar 12, 2008
6ya staff
SOURCE:
Navman on start up will not complete boot up.
Mine was doing the same. Navman advised me to hook up to the computer and access the unit in my computer,
find my documents on the navman and delete the logs. Worked for me. However now I have another problem and Navman don't know who to fix it.
Apr 02, 2009 | Audio Players & Recorders
Navman s-80 not starting up.
Did you tried to reinstall software with SmartST that came with the package? Mabe it will work.
Mar 18, 2009 | Navman iCN 530 GPS Receiver
Navman s80 boot up
on / off button jammed
Jan 17, 2009 | GPS
NAVMAN S45 GPS SET UP
http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf
click the link
model is different but system is same.
Dec 17, 2008 | GPS
Assistance Required
Every time you turn it on you have to accept the agreement. (It's so that if you have an accident, you can't sue them by saying that you didn't know that it's dangerous to look at the display while you're driving.)
Aug 17, 2008 | Audio Players & Recorders
Model s50 safety agreement shows then map loading starts then it goes back to safety agreement
contacted navman, seeing it was under warranty i have to send it back
thanks
DENISE
Jun 30, 2008 | GPS
Navman s30
Surely this is covered by warranty. Has anyone contacted Navman to find out about repair/replacement?
Jun 20, 2008 | GPS
Navman S50 Sreies
ok..so..do a firmware reset, and you should be good to go
Mar 22, 2008 | GPS
Problem with my Navman s50
hmmm..sounds like you are suffering from a firmware issue..have you downloaded any updates recently?
Mar 22, 2008 | GPS
Navman S50
My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
Dec 30, 2007 | Audio Players & Recorders
Open Questions:
GPS Logo
3,492 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
